Multiple Strips with Pushbutton Support
by joshuakane on Thu Aug 10, 2017 9:52 pm
Hi There,
I went and attempted to add push button support for my sketch. set up a case select statement that on button push should, and does cycle me through the three cases I have defined. The behavior I am seeing is that for
Case 1 - I am not seeing the delay interval that I build into the code. I wanted them to light up each pixel with a delay, but they are all illuminating at once.
Case 2 - the "Scanner" is stuck on the first pixel. It is not moving back and forth, it just illuminates pixel "0"
Case 3 - This seems to work, but again all the lights refresh at once so all the lights turn off at once.
Once Case 3 is complete, it seems to take a few prolonged button pushes to get it to cycle back to "Case 1"
I have added debugging so I know it is running thought the functions I have created such as "SaberOn" and the ones I have borrowed such as "Scanner"
If you could let me know what I am doing wrong, and not just point me to the Multi-tasking guide for Neo-Pixels it would be great.
The code is below.
#include <SoftwareSerial.h>
//---------------------------------BEGIN Yondu LIGHTING SECTION--------------------------------------------------------//
// Pattern types
enum  pattern { NONE, RAINBOW_CYCLE, COLOR_WIPE, SCANNER, SABEROFF, SABERON, COUNT_UPDOWN};
// Patern directions
enum  direction { FORWARD, REVERSE };
class YonduPatterns : public Adafruit_NeoPixel
  public:
    // Member Variables:
    pattern  ActivePattern;  // which pattern is running
    direction Direction;     // direction to run the pattern
    unsigned long Interval;   // milliseconds between updates
    unsigned long lastUpdate; // last update of position
    uint32_t Color1, Color2;  // What colors are in use
    uint16_t TotalSteps;  // total number of steps in the pattern
    uint16_t Index;  // current step within the pattern
    bool red, green, blue;
    unsigned long interval = 200;
    unsigned long previousMillis = 0;        // will store last time LED Strip was updated
    uint32_t currentColor;// current Color in case we need it
    uint16_t currentPixel = 0;// what pixel are we operating on
    // check to see if it's time to change the state of the LED
    unsigned long currentMillis = millis();
    bool UpDown = true;
    int i = 0;
    // Constructor
    YonduPatterns(uint16_t pixels, uint8_t pin, uint8_t type)
      : Adafruit_NeoPixel(pixels, pin, type)
    // Update the pattern
    void Update()
      if ((millis() - lastUpdate) > Interval) // time to update
        lastUpdate = millis();
        switch (ActivePattern)
          case RAINBOW_CYCLE:
            RainbowCycleUpdate();
            break;
          case SCANNER:
            ScannerUpdate();
            break;
          case SABEROFF:
            SaberOffUpdate();
          case SABERON:
            SaberOnUpdate();
            break;
          case COLOR_WIPE:
            ColorWipeUpdate();
          case COUNT_UPDOWN:
            CountUpDownUpdate();
            break;
          default:
            break;
    // Increment the Index and reset at the end
    void Increment()
      if (Direction == FORWARD)
        Index++;
        if (Index >= TotalSteps)
          Index = 0;
      else // Direction == REVERSE
        --Index;
        if (Index <= 0)
          Index = TotalSteps - 1;
    // Reverse pattern direction
    void Reverse()
        Direction = REVERSE;
      else
        Direction = FORWARD;
        Index = 0;
    // Initialize for a RainbowCycle
    void RainbowCycle(uint8_t interval, direction dir = FORWARD)
      ActivePattern = RAINBOW_CYCLE;
      Interval = interval;
      TotalSteps = 255;
      Index = 0;
      Direction = dir;
    // Update the Rainbow Cycle Pattern
    void RainbowCycleUpdate()
      for (int i = 0; i < numPixels(); i++)
        setPixelColor(i, Wheel(((i * 256 / numPixels()) + Index) & 255));
      show();
      Increment();
    // Update the CountUpDown Pattern
    // Initialize for a Count Up/Down
    void SaberOff(uint32_t color1, uint8_t interval, direction dir = FORWARD)
      ActivePattern = SABEROFF;
      TotalSteps = numPixels();
      Color1 = color1;
      Index = 0;
      Direction = dir;
    void SaberOffUpdate()
      Serial.println("Entering Saber Off Pattern");
      for (int i = (numPixels() - 1); i >= 0; i--)
        Serial.print("Saber On Increment # ");
        Serial.println(i);
        setPixelColor(i, Color1);
      show();
      Increment();
    void SaberOn(uint32_t color1, uint8_t interval, direction dir = FORWARD)
      ActivePattern = SABERON;
      Color1 = color1;
      Index = 0;
      Direction = dir;
    void SaberOnUpdate()
        Serial.println("Entering Saber On Pattern");
        Serial.println(i);
      show();
      Increment();
void CountUpDown(uint32_t color1, uint32_t color2, uint8_t interval, direction dir = FORWARD)
  ActivePattern = COUNT_UPDOWN;
  Color1 = color1;
  Color2 = color2;
  Index = 0;
  Direction = dir;
void CountUpDownUpdate()
  if ((unsigned long)(millis() - previousMillis) >= interval) {
    previousMillis = millis();
    if ((UpDown == true))
      Serial.print ("the vlaue of i is ");
      Serial.println (i);
      i++;
      show();
      Increment();
      if (i == 15) {
        UpDown = false;
    if ((UpDown == false))
      setPixelColor(i, Color2);
      i--;
      show();
      Increment();
      if (i == 0) {
        UpDown = true;
// Initialize for a ColorWipe
void ColorWipe(uint32_t color, uint8_t interval, direction dir = FORWARD)
  ActivePattern = COLOR_WIPE;
  Color1 = color;
  Index = 0;
  Direction = dir;
// Update the Color Wipe Pattern
void ColorWipeUpdate()
  Serial.println("Entering ColorWipe Pattern");
  setPixelColor(Index, Color1);
  show();
  Increment();
// Initialize for a SCANNNER
void Scanner(uint32_t color1, uint8_t interval)
  ActivePattern = SCANNER;
  TotalSteps = (numPixels() - 1) * 2;
  Color1 = color1;
  Index = 0;
// Update the Scanner Pattern
void ScannerUpdate()
  Serial.println("Entering Scanner Pattern");
    if (i == Index)  // Scan Pixel to the right
    else if (i == TotalSteps - Index) // Scan Pixel to the left
    else // Fading tail
      setPixelColor(i, 255, 0, 0);
  show();
  Increment();
// Calculate 50% dimmed version of a color (used by ScannerUpdate)
uint32_t DimColor(uint32_t color)
  // Shift R, G and B components one bit to the right
  uint32_t dimColor = Color(Red(color) >> 2, Green(color) >> 2, Blue(color) >> 2);
  return dimColor;
// Set all pixels to a color (synchronously)
void ColorSet(uint32_t color)
    setPixelColor(i, color);
  show();
// Returns the Red component of a 32-bit color
uint8_t Red(uint32_t color)
  return (color >> 16) & 0xFF;
// Returns the Green component of a 32-bit color
uint8_t Green(uint32_t color)
  return (color >> 8) & 0xFF;
// Returns the Blue component of a 32-bit color
uint8_t Blue(uint32_t color)
  return color & 0xFF;
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos)
  WheelPos = 255 - WheelPos;
  if (WheelPos < 85)
    return Color(255 - WheelPos * 3, 0, WheelPos * 3);
  else if (WheelPos < 170)
    WheelPos -= 85;
    return Color(0, WheelPos * 3, 255 - WheelPos * 3);
  else
    WheelPos -= 170;
    return Color(WheelPos * 3, 255 - WheelPos * 3, 0);
//---------------------------------- END Yondu Lighting SECTION ------------------------------------
#define UP 0
#define DOWN 1
#define BUTTONPIN 2             // the pin that the pushbutton is attached to
// Define some YonduPatterns for the Radar, Jolo Projector, Side lights and PSI
YonduPatterns Radar(11, 5, NEO_GRB + NEO_KHZ800); //radar has 7 LEDs in it and will be controlled on pin 5
YonduPatterns Side(10, 9, NEO_GRB + NEO_KHZ800);  //Side sections  have 15 LEDs in it and will be controlled on pin 9
// RF Pins
int         buttonState      = LOW;   // current state of the button
int         lastButtonState  = HIGH;   // previous state of the button
int         pixelState       = 0;
int         debounce_count   = 2;     // number of millis/samples to consider before declaring a debounced input
// Initialize everything and prepare to start
void setup()
  Serial.begin(9600);    // initialize serial communication
  Serial.print("Degugging Enabled");
  pinMode(BUTTONPIN, INPUT_PULLUP);
  //initialize all our LED sections
  Radar.begin();
  Side.begin();
void BumpState()
  pixelState = (pixelState + 1) % 4;  //can have values of 0, 1, or 2
// Main loop
void loop()
  // read the state of the switch into a local variable:
  buttonState = debounceRead(BUTTONPIN);
  if ((HIGH == buttonState) && (buttonState != lastButtonState))
    BumpState();
  lastButtonState = buttonState;
  switch (pixelState)
    case 1:
        Serial.println("Case 1 Fired");
        Radar.SaberOn(Radar.Color(255, 0, 0), 2000, FORWARD); //Turn the Radar on and make it solid Red
        Radar.show();
        Side.show();
        Side.SaberOn(Side.Color(255, 0, 0), 2000,  FORWARD); //Count up and down in red
        break;
    case 2:
        Serial.println("Case 2 Fired");
        Radar.Scanner(Radar.Color(255, 255, 0), 50); // Radar scans Cylon style red with 50ms interval;
        Side.SaberOn(Side.Color(255, 0, 0), 0 , FORWARD); //Count up and down in red
        break;
    case 3:
        Serial.println("Case 3 Fired");
        Radar.ColorWipe(Radar.Color(0, 0, 0), 0 , FORWARD); //Turn Solid Red
        Radar.SaberOff(Radar.Color(0, 0, 0), 50 , FORWARD); //Count down in red
        Side.SaberOff(Side.Color(0, 0, 0), 50 , FORWARD); //Count down in red
      break;
    default:
      break;
    Serial.println("Updating Radar");
  Radar.Update();
  //Serial.println("Showing Radar");
  //Radar.show();
  Serial.println("Updating Side");
  Side.Update();
  //Side.show(); */
// End Loop
uint8_t debounceRead(int pin)
  uint8_t pinState = digitalRead(pin);
  uint32_t timeout = millis();
  while (millis() < timeout + 2)
    if (digitalRead(pin) != pinState)
      timeout = millis();
  return pinState;
joshuakane
Re: Multiple Strips with Pushbutton Support
by adafruit_support_bill on Fri Aug 11, 2017 5:52 am
Your switch statement will get executed on every pass through the loop, so you will be re-initializing the pixel state machines on every pass. You want to execute that statement only once per button press.
by joshuakane on Sat Aug 12, 2017 8:02 am
Hi Bill,
I have been trying to do what you mentioned. I am trying to fire the case just once and then Exit out.
What I have noticed is that I have my modulo Set to 7, and in this example I have 6 Test Cases Setup
Each Case fires the event in an infinite loop, and never gets past the first iteration.
When I get to case 6, it does the same thing, but if I hit the button again, it does not fire any case, and the last pattern (Rainbow) runs fine. How to I make each case do that? I have tried If Statements and bools, but they are not helping.
//Yondu lights and sound version 0.2 alpha
//Author: Derick Hess
// Based on NeoPatterns by Bill Earl found at https://learn.adafruit.com/multi-tasking-the-arduino-part-3/using-neopatterns
//Feel free to use and modify this as you see fit.
//Please give credit to both myself and Bill Earl if you redistrubute the code
//lighting only works soudn to be added later.
//This code uses NeoPixel style RGB LEDs you can find them on amazon or adafruit as individual LEDs or in strips
// I used these: http://www.amazon.com/gp/product/B00P2GQUYC?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s01
//you could also use the predone bars or possibly even rolls, as long as they are the RGB individually addressable LEDS
// Pattern types
enum  pattern { NONE, RAINBOW_CYCLE, THEATER_CHASE, SCANNER, FADE, SOLID_COLOR_RADAR, RANDOM, COLOR_WIPE };
    public:
    unsigned long jIinterval = 200;
    // Constructor
    :Adafruit_NeoPixel(pixels, pin, type)
    void Update()
        if((millis() - lastUpdate) > Interval) // time to update
            switch(ActivePattern)
                case RAINBOW_CYCLE:
                    break;
                case THEATER_CHASE:
                    TheaterChaseUpdate();
                    break;
                case SCANNER:
                    ScannerUpdate();
                    break;
                case FADE:
                    FadeUpdate();
                    break;
                case SOLID_COLOR_RADAR:
                    SolidColorRadarUpdate();
                    break;
                case RANDOM:
                    RandomUpdate();
                    break;
                case COLOR_WIPE:
                    ColorWipeUpdate();
                    break;
                default:
                    break;
    void Increment()
           Index++;
                Index = 0;
            --Index;
            if (Index <= 0)
                Index = TotalSteps-1;
    void Reverse()
        else
            Index = 0;
        TotalSteps = 255;
        Index = 0;
        Direction = dir;
        for(int i=0; i< numPixels(); i++)
        show();
        Increment();
    // Initialize for a Random
    void Random(uint8_t interval, bool redOnOff,bool greenOnOff, bool blueOnOff )
        ActivePattern = RANDOM;
        Index = 0;
        red=redOnOff;
        green=greenOnOff;
        blue=blueOnOff;
    // Update the random Pattern
    void RandomUpdate()
      int randomOnOff=0;
      int randomGreen=0;
      int randomBlue=0;
      int randomRed=0;
            randomSeed(analogRead(0));
            randomOnOff=random(0,100); //get a random number for led on or off
            if (green == 1){
            randomGreen=random(0,50);  //random green
            else{
               randomGreen=0;  //random green
             if (blue == 1){
            randomBlue=random(0,50);  //random green
            else{
               randomBlue=0;  //random green
             if (red == 1){
            randomRed=random(0,255);  //random green
            else{
               randomRed=0;  //random green
            if (randomOnOff > 20)  // if greater than 50 led is on and random color
            setPixelColor(i, randomRed,randomGreen,randomBlue); //random value for the blue and green of the LED
            else  //otherwise it's off
              setPixelColor(i, 0,0,0);  //LED off
        show();
        Increment();
    // Initialize for a Theater Chase
    void TheaterChase(uint32_t color1, uint32_t color2, uint8_t interval, direction dir = FORWARD)
        ActivePattern = THEATER_CHASE;
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Theater Chase Pattern
    void TheaterChaseUpdate()
            if ((i + Index) % 3 == 0)
            else
        show();
        Increment();
    // Initialize Solid Color
    void SolidColorRadar(uint32_t color, uint8_t interval, direction dir = FORWARD)
        ActivePattern = SOLID_COLOR_RADAR;
        TotalSteps = 23;
        //TotalSteps = numPixels();
        Color1 = color;
        Index = 0;
        Direction = dir;
    void SolidColorRadarUpdate(){
        show();
        Increment();
        Color1 = color1;
        Index = 0;
            else // Fading tail
                 setPixelColor(i, DimColor(getPixelColor(i)));
        show();
        //Increment();
    // Initialize for a Fade
    void Fade(uint32_t color1, uint32_t color2, uint16_t steps, uint8_t interval, direction dir = FORWARD)
        ActivePattern = FADE;
        TotalSteps = steps;
        Color1 = color1;
        Color2 = color2;
        Index = 0;
        Direction = dir;
    // Update the Fade Pattern
    void FadeUpdate()
        // Calculate linear interpolation between Color1 and Color2
        // Optimise order of operations to minimize truncation error
        uint8_t red = ((Red(Color1) * (TotalSteps - Index)) + (Red(Color2) * Index)) / TotalSteps;
        uint8_t green = ((Green(Color1) * (TotalSteps - Index)) + (Green(Color2) * Index)) / TotalSteps;
        uint8_t blue = ((Blue(Color1) * (TotalSteps - Index)) + (Blue(Color2) * Index)) / TotalSteps;
        ColorSet(Color(red, green, blue));
        show();
        Increment();
        return dimColor;
        show();
        if(WheelPos < 85)
        else if(WheelPos < 170)
            WheelPos -= 85;
        else
            WheelPos -= 170;
      Color1 = color;
      Index = 0;
      Direction = dir;
      show();
      Increment();
char val;         // variable to receive data from the serial port
// Define some YonduPatterns for the Radar, & Side
YonduPatterns Radar(10, 5, NEO_GRB + NEO_KHZ800); //radar has 4 LEDs in it and will be controlled on pin 5
YonduPatterns Side(10, 9, NEO_GRB + NEO_KHZ800);  //Side sections  have 6 LEDs in it and will be controlled on pin 7
// RF Pins
int         pixelState       = 0;
void setup()
  Serial.begin(9600); //setup serial connection
    Radar.begin();
     Side.begin();
      Radar.SolidColorRadar(Radar.Color(255,0,0),100, FORWARD);
      Side.SolidColorRadar(Side.Color(255,0,0), 100, FORWARD);
void BumpState()
  pixelState = (pixelState + 1) % 7;  //can have values of 0 - 6
// Main loop
void loop()
    BumpState();
  switch (pixelState)
      case 1:
      Serial.println("Yondu Case 1 Fired");
      break;
    case 2:
      Serial.println("Yondu Case 2 Fired");
      Side.SolidColorRadar(Side.Color(255,0,0),0, FORWARD);
      break;
    case 3:
      Serial.println("Yondu Case 3 Fired");
      Radar.SolidColorRadar(Radar.Color(0,0,0), 100, REVERSE);
      Side.SolidColorRadar(Side.Color(0,0,0), 100, REVERSE);
      break;
    case 4:
      Serial.println("Yondu Case 4 Fired");
      Radar.Scanner(Radar.Color(0, 100, 00), 100);
      Side.Fade(Side.Color(0, 0, 100), Side.Color(0, 0, 05), 100, 40, REVERSE);
      break;
    case 5:
      Serial.println("Yondu Case 5 Fired");
      Radar.SolidColorRadar(Radar.Color(255, 0, 0), 0, FORWARD);
      break;
    case 6:
      Serial.println("Yondu Case 6 Fired");
      Side.RainbowCycle(10);
      Radar.SolidColorRadar(Side.Color(255,0,0), 100, REVERSE);
        if (HIGH == buttonState &&  lastButtonState == LOW)
              BumpState();
      break;
//at the end of the loop we upfate all the patterns
Radar.Update();
Side.Update();
      timeout = millis();
  return pinState;
joshuakane
by adafruit_support_bill on Sat Aug 12, 2017 8:14 am
You are still calling the switch statement in every pass through the loop, so every pass will re-initialize whatever the current state is.
If you move the switch statement into your BumpState() function, it will only initialize on a state change.
by joshuakane on Sat Aug 12, 2017 9:40 am
Thank you very much Bill. That did the trick. This is going into a "Yondo" costume from Guardians of the Galaxy. It is being debueted over Labor Day weekend at Dragon*Con in Atlanta. There will also be a Sakar Ogord using adafruit lights and processors. If you like I can send pictures and hardware used for your cosplay folks.
joshuakane
by adafruit_support_bill on Sat Aug 12, 2017 10:30 am
Good to hear it is working. If you have some good photos, post them here and I'll see if we can get them up on the blog.
