I2c eeprom with Adafruit numeric display
by BReeves on Sat Aug 12, 2017 4:30 am
Have two numeric displays with I2c backpacks on the way, what I am wondering is if I can hang a I2c eeprom on the I2c buss and use the backpack driver to access it? I have a few 24C256 eeproms on order but not sure if it will be compatible with the backpack chip. Wouldn't be against using a different eeprom if the 24C256 simply will not work. If it matters I will be using a Teensy 2.0 with the Arduino libraries.
BReeves
Re: I2c eeprom with Adafruit numeric display
by adafruit_support_rick on Sat Aug 12, 2017 12:09 pm
I don't know what you mean about using the backpack driver to access the eeprom. You'll need a separate driver for the eeprom.
However, as long as the I2C addresses don't conflict, you'll be able to use the eeprom on the same I2C bus as the display
by BReeves on Sun Aug 13, 2017 4:52 am
Sorry, should have said "Library" instead of "Driver". Just discovered the Teensy has a 1024 byte eeprom built in and will not need the external eeprom. Sorry to have bothered with what ended up being an irrelevant question.
BReeves
