[WHITE SCREEN] HDMI 7" 800X480 DISPLAY BACKPACK - W/TOUCHSCR
by christianboyle on Sat Aug 12, 2017 10:10 am
https://www.adafruit.com/product/2407
I ordered this and tried using it with 2 different Raspberry Pi's with the same result each time - a white screen with a rotating scanline.
Both RPi's work as expected when plugging into a TV using the same HDMI cable used in testing, so I assume this must be some issue with the display itself.
christianboyle
Re: [WHITE SCREEN] HDMI 7" 800X480 DISPLAY BACKPACK - W/TOUC
by adafruit_support_rick on Sat Aug 12, 2017 11:51 am
Did you configure the Pi for the correct screen resolution?
https://learn.adafruit.com/adafruit-5-8 ... -pi-config
by christianboyle on Sat Aug 12, 2017 9:16 pm
adafruit_support_rick wrote:Did you configure the Pi for the correct screen resolution?
This fixed it, thanks!
christianboyle
cron
