Adafruit_SSD1305 library & Feather M0
by danchen on Sat Aug 12, 2017 10:15 am
Does the Adafruit_SSD1305 Library works with Feather M0 with
Monochrome 2.42" 128x64 OLED Graphic Display Module Kit
https://www.adafruit.com/product/2719
danchen
Re: Adafruit_SSD1305 library & Feather M0
by adafruit_support_rick on Sat Aug 12, 2017 11:15 am
It should work. There are no hardware dependencies.
There were some problems with the library, which I fixed. Unfortunately, I don't have one here to test.
by danchen on Sat Aug 12, 2017 6:02 pm
Thank you!
When I run the test code "ssd1305test.ino", I get
'srandom' was not declared in this scope
Is there something that I forgot to include?
thanks!
danchen
by franklin97355 on Sat Aug 12, 2017 6:05 pm
srandom may be in the avr core libraries and not available to the M0 code. You could write your own function to replace this.
franklin97355
by adafruit_support_rick on Sun Aug 13, 2017 12:14 pm
Srandom is an old Arduino call. I fixed the example sketch so that it uses modern function calls. Please get the latest sketch from the library
by danchen on Sun Aug 13, 2017 12:24 pm
Thank you! It works great with M0 now!
danchen
