I was trying out my new Jewel:
https://www.adafruit.com/product/2226
but trying the "rainbow" example from:
https://learn.adafruit.com/gemma-m0-she ... nbow-cycle
the example code did not work - it just left the pixels off
Here is the example:
# Gemma IO demo - NeoPixel
from digitalio import *
from board import *
import neopixel
import time
pixpin = D2
numpix = 7
led = DigitalInOut(D13)
led.direction = Direction.OUTPUT
strip = neopixel.NeoPixel(pixpin, numpix, brightness=0.3)
def wheel(pos):
# Input a value 0 to 255 to get a color value.
# The colours are a transition r - g - b - back to r.
if (pos < 0):
return [0, 0, 0]
if (pos > 255):
return [0, 0, 0]
if (pos < 85):
return [int(pos * 3), int(255 - (pos*3)), 0]
elif (pos < 170):
pos -= 85
return [int(255 - pos*3), 0, int(pos*3)]
else:
pos -= 170
return [0, int(pos*3), int(255 - pos*3)]
def rainbow_cycle(wait):
for j in range(255):
for i in range(len(strip)):
idx = int ((i * 256 / len(strip)) + j)
strip[i] = wheel(idx & 255)
strip.write()
time.sleep(wait)
while True:
rainbow_cycle(0.001)
I also removed the setting for D13 and the call to strip.write() since they were not needed.
Revised example:
from board import *
import neopixel
import time
pixpin = D2
numpix = 7
def wheel(pos):
if (pos < 0):
return (0, 0, 0)
if (pos > 255):
return (0, 0, 0)
if (pos < 85):
return (int(pos * 3), int(255 - (pos*3)), 0)
elif (pos < 170):
pos -= 85
return (int(255 - pos*3), 0, int(pos*3))
else:
pos -= 170
return (0, int(pos*3), int(255 - pos*3))
time.sleep(wait)
while True:
I'm not proficient enough in Python to clearly explain the difference between "()" and "[]" so I'll let someone else comment of they want.
this works for me - your mileage may vary ;-)
