Hey all -
I built the gemma-powered scarf (https://learn.adafruit.com/animated-neo ... -fur-scarf) - great guide, thank you! I built it a couple weeks ago and was really enjoying it.
I went to re-program it yesterday, and after uploading the whole strip just stayed white + the red reset-indicator light was a dull solid red. Based on my research on the forums, it appears that the most likely cause is that the battery was too low (I was powering it off a USB 2 hub connected to my macbook).
Does that sound like the right diagnosis? I'm going to charge the battery off a wall outlet tonight and try again, and I wanted to see if there was anything else I should research beforehand (like, could I have somehow messed up the bootloader?...although all I did was upload a slightly tweaked version of the provided code.)
Led strip all white = not enough battery power?
- dlinsalata
- splatten
Re: Led strip all white = not enough battery power?
How may LED's do you have in the strip?
- dlinsalata
~77 (half of what the project calls for). It was working fine for a while and seems like it stopped on my latest code upload.
I charged the battery fully last night and tried to run it off that - now it doesn't even get to white LEDs - just turns on with the reset light on dimly. It seems almost like when I was running it off USB3...except I can't think of anything that changed from when I had this working minus re-uploading the code.
- splatten
You can calculate the amount of current required based on the number of LED's and the RGB values you are trying to send to the LED's. I have blown small power supplies before that did not have current limiting on them. You are driving it from batteries, whats the maximum current you can draw? Is it sufficient?
