raspberrypi-kernel : Breaks: raspberrypi-bootloader (< 1.201
Re: raspberrypi-kernel : Breaks: raspberrypi-bootloader (< 1
by chrisham on Sat Nov 04, 2017 1:57 pm
I will try the manual method and get back.
chrisham
by adafruit2 on Sat Nov 04, 2017 9:19 pm
stretch keeps updating >.< we're going to be working on this for the next few days to find some long term solution!
adafruit2
Site Admin
by chrisham on Sun Nov 05, 2017 2:36 am
chrisham
by basselt on Sun Nov 05, 2017 7:22 am
Sounds good. Looking forward... Have door unlock system with Pi set up, would really love to see the touchscreen working, gives me more options
basselt
by adafruit2 on Mon Nov 06, 2017 2:00 am
ok i am almost done writing up a new set of instructions that do not require a new kernel - can any of y'all help test? i need another day to wrap up some stuff. are any of you using PIXEL desktop or is this console-use only?
adafruit2
Site Admin
by basselt on Mon Nov 06, 2017 5:40 am
I am using Pixel with Stretch. So anytime,
regards, Bob
basselt
by adafruit2 on Wed Nov 08, 2017 1:51 am
ok im pretty rusty at shell scripting, and absolutely *everything* changed :D still working...
adafruit2
Site Admin
by adafruit2 on Wed Nov 08, 2017 2:00 am
ok here's my first draft! its for all pitft acreens.
$ cd ~
$ wget https://raw.githubusercontent.com/adafruit/Adafruit-PiTFT-Helper/master/adafruit-pitft-helper2.sh
$ chmod +x adafruit-pitft-helper2.sh
$ sudo ./adafruit-pitft-helper2.sh
you can select text console or PIXEL graphical!
adafruit2
Site Admin
by basselt on Wed Nov 08, 2017 5:04 pm
I have a 3.5 TFT. Wait for more or try it anyhow?
Grtz
B
basselt
by adafruit2 on Wed Nov 08, 2017 5:14 pm
sorry you have to wait for now! it will be a few days - thanks !!! :)
adafruit2
Site Admin
by basselt on Wed Nov 08, 2017 5:57 pm
OK
basselt
by adafruit2 on Fri Nov 10, 2017 1:36 am
ok 3.5" is/should be working now as well as the 2.8" capacitive, please try the same script above!
adafruit2
Site Admin
by basselt on Sun Nov 12, 2017 12:20 pm
Okay...
On PI2 with 3.5 PiTFT; installed a fresh Stretch, update, cleaned, removed office and extra's I don't need (did not touch Python) and ran your script.
did choose 3.5, did not get question console or PIXEL, just "do you want console" Did choose no, rebooted, blank TFT; however touch is working! So standard pict (Pixel Desktop) on HDMI, touch screen works, but no picture, plus X axis inverted
Re-ran script, did choose yes now. And yes console was there. HDMI dead (of course)
Did re-run script telling the script it was a 2.8 (choice1) same thing.
New image installed, updated etc, ran script, no console, HDMI mirror, got these messages
sh: 0: getcwd() failed: No such file or directory
reboot=>same effect, no pict on TFT, touch is working, but inverted X. Do have pict from Pixel desktop on HDMI in TFT resolution.
Config.txt:
[pi0]
device_tree=bcm2708-rpi-0-w.dtb
[pi1]
device_tree=bcm2708-rpi-b-plus.dtb
[pi2]
device_tree=bcm2709-rpi-2-b.dtb
[pi2]
device_tree=bcm2710-rpi-3-b.dtb
[all]
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
dtoverlay=pitft35-resistive,rotate=270,speed=32000000,fps=20
# --- end adafruit-pitft-helper zo 12 nov 2017 17:09:18 CET ---
hdmi_group=2 (removed from item '...this will force vga' further up in config)
hdmi_mode=87 (removed from item '...this will force vga' further up in config)
hdmi_cvt=720 480 60 1 0 0 0
Will keep experimenting...
Grtz
Bob
PS staring in console gives console on TFT; following with "sudo systemctl start lightdm" opens the desktop on HDMI
basselt
by adafruit2 on Sun Nov 12, 2017 1:21 pm
if you want PIXEL, get your pi to Boot To Desktop, run the script, and select "Mirror HDMI" - try that!
adafruit2
Site Admin
by basselt on Sun Nov 12, 2017 1:52 pm
Did that as well. raspi config boot to desktop auto login. script installed, choose HDMI mirror: As I wrote, screen does work as touch screen, however inverted axes, and Pixel on HDMI. No desktop on TFT.
B
basselt
