Small dimension bitmap does not display correctly on TFT
by dbj1906 on Mon Sep 11, 2017 12:10 pm
I am using a TFT featherwing (ID: 3315) with an M0 wifi feather (ID: 3010). I am able to get the purple flowers images to appear using the full_featherwing example.
I have problems when displaying a bitmap of smaller dimensions (like the 100x100 thumbnail of the [url="https://cdn-learn.adafruit.com/assets/assets/000/015/405/thumb100square/adafruit_products_purple.bmp?1395107585"]flower bitmap[/url]).
The image is "scrunched" (for lack of a better word), like so:
Any thoughts? I need to add three or four bitmaps as icons, and I'm not sure how to go about it.
[Note - I performed the same test with an ESP8266 feather, and got the same results. I also reformatted my SD card).
dbj1906
Re: Small dimension bitmap does not display correctly on TFT
by dbj1906 on Tue Sep 12, 2017 10:22 pm
I tried the same picture using the "spitftbitmap" example and it worked!
dbj1906
by edgarlz123 on Sun Nov 05, 2017 10:30 am
I'm having the same problem with the 3.5" featherwing and the M0 wifi (ATWINC1500), did you have any luck? I also tried with the spitftbitmap example and didn't work.
edgarlz123
by edgarlz123 on Thu Nov 09, 2017 4:33 am
Just so you can know, I copied the SD functions from the spitftbitmap example of the ILI9341 library and it's now finally working! :D
edgarlz123
by Es210 on Sun Nov 19, 2017 7:12 pm
Yes, I was able to display a smaller bmp (84x87) when I replaced the bmpDraw() function in the HX8357 Library spitftbitmap example with the bmpDraw() function in the ILI9341 Library spitftbitmap example.
Es210
