I'm trying to power a 1.2" 4-digit 7-segment display from a Feather 32u4 or Feather HUZZAH. I'm using a PowerBoost 500 Basic to provide 5 volts to the display. The display isn't working with the basic backpack test. When I connect the smaller 0.56" display, it works and is nice and bright.
I've seen similar requests, but they have ended up not needing the 5v. Any help or suggestions would be great.
Feather 3v to Boost Bat
Feather GND to Boost GND
Boost 5v to Display +5V
Feather 3v to Display VIO
Feather GND to Display GND
Feather SDA to Display SDA
Feather CLK to Display CLK
https://www.adafruit.com/product/1268
https://www.adafruit.com/product/1903
Feather and 1.2" 4-digit 7-segment display
- moWhite
Re: Feather and 1.2" 4-digit 7-segment display
I'm embarrassed to note that I posted a similar question one year ago. Sorry for the duplication. I'm doing some more testing and will post pictures and verification that the display is working.
Maybe I'm asking the wrong question: Given a Feather with 3.3v circuits, what is the best way to power a 5v display?
- adafruit_support_rick
Don't think you want to do that. 3V is supposed to be 3V. It's the output from the voltage regulator. The battery is more than 3V, so you could damage your feather. You want to connect the Boost 5V to the Feather USB pin.moWhite wrote:Feather 3v to Boost Bat
Try running the i2cScanner sketch and see if the display shows up.
https://playground.arduino.cc/Main/I2cScanner
Also, post some pictures of your soldering and wiring.
- moWhite
I'll try the i2c scanner and post pictures. Thanks.
To be clear, I'm using 3v from the feather to power the boost and then using the boost to power the LED. Boost BAT is power in.
? How are you powering the feather? From a battery?moWhite wrote:To be clear, I'm using 3v from the feather to power the boost and then using the boost to power the LED. Boost BAT is power in.
You really don't want to drive the display from the feather's 3V. The display can take up to 120mA/digit. The feather's voltage regulator is only good to 500mA peak - and you can't run it at peak continuously. The boost will have its own inefficiencies as well. Taken together, you're overloading the voltage regulator. That;s probably why it doesn't work.
If you're running from a battery, use the battery voltage directly to drive the display. Or use the battery voltage to drive the power boost.
