LED matrix not working...
CrazyPharaoh
Post by CrazyPharaoh »
Hi, i have the 8x8 1.2" LED matrix. its a great piece of kit but i have one issue, when i light up all the LEDs, the matrix flickers and is dimmed, as if it doesnt have enough power. But if i light 54 of the 64 LEDs, the same thing happens for about 5 seconds then it lights up normally with normal brightness.
I have no idea why its not working, here is the code just incase...(and yes, its an adaptation of the example)
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_8x8matrix matrix = Adafruit_8x8matrix();
  Serial.begin(9600);
  Serial.println("8x8 LED Matrix Test");
  matrix.begin(0x70);  // pass in the address
static const uint8_t PROGMEM
  full_bmp[] =
  { B11111111,
    B11111111,
    B11100011,
    B11100011,
    B11111110,
    B11111111,
    B11111111,
    B11111000},
  neutral_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10111101,
    B10000001,
    B01000010,
    B00111100 },
  frown_bmp[] =
  { B00111100,
    B01000010,
    B10100101,
    B10000001,
    B10011001,
    B10100101,
    B01000010,
    B00111100 };
  matrix.clear();
  matrix.drawBitmap(0, 0, full_bmp, 8, 8, LED_ON);
  matrix.writeDisplay();
Reason: Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
CrazyPharaoh
Re: LED matrix not working...
I have a quick update... if i connect the DAT pin to the CLK pin, the matrix works properly! But, i still need to know if that's dangerous or not good for the backpack in any way (and it would be great to get it to work normally).
So if someone could fill me in, that would be great! Thanks in advance!
