Neopixel Jewel 10 Minute Necklace
by jeremyzschau on Sat Sep 30, 2017 8:22 am
How do I edit the colors?
#define PIN 1
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(40, PIN);
uint8_t  mode   = 0, // Current animation effect
         offset = 0;
uint32_t color  = 0X00A4B3; // Starting color
uint32_t prevTime;
  pixels.begin();
  pixels.setBrightness(40); // 1/3 brightness
  prevTime = millis();
  uint8_t  i;
  uint32_t t;
  switch(mode) {
   case 0: //rainbow hold
    rainbowHold(20);
    delay(500);
    break;
   case 1: //rainbow cycle slow
    rainbowCycleslow(20);
    delay(50);
    break;
   case 2: //rainbow cycle fast
    rainbowCycle(5);
    delay(50);
    break;
  t = millis();
  if((t - prevTime) > 8000) {      // Every 8 seconds...
    mode++;                        // Next mode
    if(mode > 3) {                 // End of modes?
      mode = 0;                    // Start modes over
      color >>= 8;                 // Next color R->G->B
      if(!color) color = 0xB300A4; // Reset color
    for(i=0; i<32; i++) pixels.setPixelColor(i, 0);
    prevTime = t;
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<pixels.numPixels(); i++) {
      pixels.setPixelColor(i, Wheel((i+j) & 255));
    pixels.show();
    delay(wait);
void rainbowCycle(uint8_t wait) {
  uint16_t r, j;
  for(j=0; j<256*6; j++) { // 6 cycles of all colors on wheel
    for(r=0; r< pixels.numPixels(); r++) {
      pixels.setPixelColor(r, Wheel(((r * 256 / pixels.numPixels()) + j) & 255));
    pixels.show();
    delay(wait);
void rainbowCycleslow(uint8_t wait) {
  uint16_t r, j;
  for(j=0; j<256*3; j++) { // 3 cycles of all colors on wheel
    pixels.show();
    delay(wait);
void rainbowHold(uint8_t wait) {
  uint16_t r, j;
  for(j=0; j<256*1; j++) { // 3 cycles of all colors on wheel
    pixels.show();
    delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
   return pixels.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  } else if(WheelPos < 170) {
   WheelPos -= 85;
   return pixels.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  } else {
   WheelPos -= 170;
   return pixels.Color(0, WheelPos * 3, 255 - WheelPos * 3);
jeremyzschau
Re: Neopixel Jewel 10 Minute Necklace
by adafruit_support_bill on Sat Sep 30, 2017 8:37 am
It goes through the entire rainbow. Which colors do you want to change?
by jeremyzschau on Sat Sep 30, 2017 8:49 am
I would like to make more purples and blues. Could the RGB value numbers be written in the code?
jeremyzschau
by adafruit_support_bill on Sat Sep 30, 2017 9:11 am
You can remove the green part of the wheel() function, so it just works in the red-purple-blue range
Something like this:
// The colours are a transition r - b - back to r.
  if ((wheelPos < 127)
     return pixels.Color(255 - WheelPos * 2, 0, WheelPos * 2); // red to blue
  else
     WheelPos -= 127;
     return pixels.Color(WheelPos * 2, 0, 255 - WheelPos * 2); // blue to red
by jeremyzschau on Wed Oct 04, 2017 5:52 pm
OK. Thank you. I don't want any red but I understand if it can't be done.
jeremyzschau
by adafruit_support_bill on Wed Oct 04, 2017 6:29 pm
Well, purple is red plus blue. So one way or another you you do need at least some red. You can make further tweaks to the wheel code to reduce the red.
by jeremyzschau on Thu Oct 05, 2017 6:13 pm
OK. Thank you.
jeremyzschau
