JST connector current capacity
by featMikeTyson on Thu Oct 05, 2017 2:11 pm
I am looking to drive 2 meters of 144 LED Neopixel strip, and have designed the power circuit around the max theoretical current draw of 17.3A (safety first!)
Looking up the datasheet for the JST-SM connector, the current limit per pin is 3A, and is connected to AWG22 wire (~7A spec'd).
Assuming a linear power relationship (ha!), this would suggest I would be able to drive my strip at a maximum mixed-color duty cycle of around 17%. This is not an unreasonable operating point, but it also makes me wonder what the width of the power traces are (etc) and that makes me a little nervous, especially when considering the discharge of 1000uF cap recommended for voltage ramp-up, or in the event of a software bug overdriving the strip.
Can someone please advise?
featMikeTyson
Re: JST connector current capacity
by adafruit_support_bill on Thu Oct 05, 2017 7:01 pm
With 2 meters of 144 pixel strip, you will probably want to feed power to at least two points (e.g. both ends) to minimize voltage drop. It is also a good practice to fuse each branch of the circuit to protect the wire in the event of a catastrophic short circuit.
The generally accepted ampacity for 22AWG in a 'chassis wiring' application is in the 7A range. a 7A in-line fuse on each power feed would be a safe way to go.
cron
