Wall/brick inverter for EL wire
by HollyD1970 on Fri Oct 06, 2017 3:40 pm
Hello! I'm looking to add some EL wire to wall decor, so it'd be a fixed setup, with longer glow time desire than wearables. As such, a battery-based inverter is out. I see this: https://www.adafruit.com/product/448 but the description is a little sparse for a casual user like myself, where it says "you can just plug it into a 12V wall adapter." I'm seeing some bare/unterminated wires there... what needs to be added/soldered/whatevered to that end, in order to ultimately plug this thing into the wall? :)
HollyD1970
Re: Wall/brick inverter for EL wire
by adafruit_support_bill on Fri Oct 06, 2017 4:32 pm
You can use an adapter like this: https://www.adafruit.com/product/368
To connect the bare wires from the inverter to a power supply like this: https://www.adafruit.com/product/798
by HollyD1970 on Fri Oct 06, 2017 4:43 pm
Awesome, thanks! I may actually have those already :)
HollyD1970
