Can the RA8875 change Font?
by Forge on Fri Oct 06, 2017 6:42 pm
So I have been trying to get a little prototype for a product going and I am running into a silly issue I can not solve. I have a Arduino Mega 2560 R3 hooked up to a 7" TFT LCD with a RA8875 chip. I am simply trying to change my font; specifically to any of the ones included with the adafruit_gfx library. I'll post some code here to see if anyone can spot anything wrong.
Note that everything compiles and uploads smoothly without error. The LCD touchscreen also works very well and visual stuff such as the adafruit graphics demo runs well too.
I just cant change font. I also noticed
#include <SPI.h>
#include <Adafruit_GFX.h>
#include <Adafruit_RA8875.h>
#include <Fonts/FreeSansBold24pt7b.h>
#define RA8875_INT 4
#define RA8875_CS 10
#define RA8875_RESET 9
Adafruit_RA8875 tft = Adafruit_RA8875(RA8875_CS, RA8875_RESET);
uint16_t tx, ty;
float xScale = 1024.0F/850.0;
float yScale = 1024.0F/545.0;
  Serial.begin(9600);
  tft.begin(RA8875_800x480);
  tft.displayOn(true);
  tft.GPIOX(true);
  tft.PWM1config(true, RA8875_PWM_CLK_DIV1024);
  tft.PWM1out(255);
  tft.textMode();
  tft.setFont(&FreeSansBold24pt7b);
  tft.textSetCursor(80,200);
  tft.textEnlarge(8);
  tft.print("AXCDW0129314");
Forge
Re: Can the RA8875 change Font?
by adafruit_support_rick on Sat Oct 07, 2017 9:03 am
tft.textMode sets the RA8875 to use its internal font. Don't go into text mode if you want to use a GFX font
by Tim_wb0wuq on Sat Jan 12, 2019 1:53 pm
I have the same issue. I have the Adafruit metro mini https://www.adafruit.com/product/2590 The Adafruit https://www.adafruit.com/?q=ra8875
The sketch compiles and loads, but does not render the fonts.
This same sketch compiles and loads with the 2.8" TFT LCD with touchscreen. https://www.adafruit.com/product/1770 and works great.
Please help!!
Tim
font_test.ino
(1.76 KiB) Downloaded 14 times
Tim_wb0wuq
by Tim_wb0wuq on Sat Jan 12, 2019 1:54 pm
I have the same issue. I have the Adafruit metro mini https://www.adafruit.com/product/2590 The Adafruit https://www.adafruit.com/?q=ra8875 with this screen https://www.adafruit.com/product/2354
All adafruit items.
Please help!!
Tim
font_test.ino
(1.76 KiB) Downloaded 8 times
Tim_wb0wuq
