Lots and lots and lots of LEDs
by benforta on Sun Oct 08, 2017 3:25 pm
I am working on a project that will have lots of RGB LEDs, lots as in 4,000+, of which 2,000+ could be lit at any time. I can use DotStar or NeoPixel. I am not worried about power issues at this point, right now I am trying to figure out how to control them.
My preference would be to use Raspberry Pi (as the project needs Internet access, and I also have lots of existing Python code that I'd rather not rewrite in C). However, I am having a really hard time getting the pixels to behave well with the Pi. Plus, I am seeing that the libraries aren't really designed for strips thousands of pixels long. And FadeCandy is designed for far too few LEDs.
I could use Arduino or Teensy, etc. if needed, but I have only ever driven a few hundred LEDs that way. Has anyone driven thousands?
Are there are other options I am not thinking of? How are any of you driving thousands of RGB LEDs?
--- Ben
benforta
Re: Lots and lots and lots of LEDs
by adafruit_support_bill on Sun Oct 08, 2017 4:07 pm
The Teensy with an OctoWS2811 adapter is what you are looking for.
https://www.adafruit.com/product/1779
https://www.adafruit.com/product/3266
The OctoWS2811 library from PJRC is designed to handle thousands of LEDs:
https://www.pjrc.com/teensy/td_libs_OctoWS2811.html
by benforta on Sun Oct 08, 2017 4:21 pm
Thanks, I'll give that a try. It looks like that supports NeoPixel, but not DotStar. Correct? Any way to use that with a RPi, or do you know of something similar for RPi?
--- Ben
benforta
by adafruit_support_bill on Sun Oct 08, 2017 4:38 pm
The OCtoWS2811 is designed for Neopixels (WS2811/WS2812).
he Pi is not capable of reliably driving Neopixels. If you want to use a Pi, then DotStars are the way to go. But I don't know of any libraries specifically designed for large numbers of DotStars.
by benforta on Sun Oct 08, 2017 4:44 pm
Then NeoPixels it is.
One last question. Looks like Teensy has no on-board WiFi. Do you know which Arduino compatible WiFi option will work well with Teensy and the OctoWS2811?
As always, thanks for your help!
--- Ben
benforta
by adafruit_support_bill on Sun Oct 08, 2017 7:33 pm
There are a number of workable WiFi options. There is a thread on that topic here in the Teensy forums: https://forum.pjrc.com/threads/42215-Ad ... Teensy-3-x
