Wanted: Higher Resolution Small LCDs
by ethur on Mon Oct 09, 2017 5:03 pm
One product area I'd love to see from Adafruit are higher resolution but small LCD screens. For example, 2 to 3.5 inch displays with at least 800x480 or higher, especially ones that would be compatible with an HDMI driver board.
These would be perfect for two things:
- VR headsets
- DIY viewfinders for video work
ethur
Re: Wanted: Higher Resolution Small LCDs
by adafruit_support_rick on Tue Oct 10, 2017 12:34 pm
I'll pass along the suggestion!
by adafruit2 on Tue Oct 10, 2017 12:35 pm
these are very hard to find, right now the smallest you can get for 800x480 is 3.5"
adafruit2
Site Admin
by riklaunim on Wed Oct 11, 2017 10:16 am
You can adapt MIPI DSI smartphone screens to work with some STM microcontrollers or via some FPGA magic - as a HDMI display. Making VR headsets similar to those on the consumer market will be extremely hard and costly - the IP and unique hardware is held closed by given vendor - so at best you could mimic chinese display-glasses.
riklaunim
by ethur on Fri Nov 03, 2017 12:23 am
My own personal quest is to make an external viewfinder for my video camera. I actually started off by buying one of the inexpensive 800x480 projectors from China ($85 CDN), and then ripping it apart for the LCD panel and driver board. Everything works, but it isn't ideal because (a) the screen is a bit bigger than I'd like at 4.3" and (b) the driver board has an overly-large shape that is forcing me to make the enclosure bigger than I'd like. (It has an extra wing simply to extend the ribbon cable connection.)
The new Pimoroni HyperPixel - 3.5" Hi-Res Display is the kind of screen I'd be hoping to find, albeit with an HDMI connection.
ethur
