RGB Matrix Graphics
RGB Matrix Graphics
by adamr1 on Mon Oct 09, 2017 9:39 pm
Hello. I am working on a project using the 3mm 64x32 LED matrix. I am using a tool I found online called LED Matrix Studio. I am trying to covert a BMP to be displayed on the matrix (in color). This tool exports the pixel info into an array like:
 uint32_t ledarray[]= {
0xFFFFFF00, 0x62858100, 0xCAD1EE00..... }
My plan was to loop through data to display each pixel.
Is there a way to display this information using the matrix?
Thank you.
adamr1
Re: RGB Matrix Graphics
by adafruit_support_rick on Tue Oct 10, 2017 12:57 pm
Sure. You copy and paste that array to your sketch.
Go into a loop and call matrix.drawPixel(x, y, matrix.Color888(r, g, b)); with the data from the array.
Something like this
  uint8_t *arrayPtr = (uint8_t)ledarray;
  for (int x=0; x < 64; x++)
    for (int y=0; y < 32; y++)
        uint8_t r = *arrayPtr++;
        uint8_t g = *arrayPtr++;
        uint8_t b = *arrayPtr++;
        arrayPtr++;  //skip 4th byte
Now, the above is just an outline of the general procedure. I don't know the color order or the array x,y order in the array data, so you may have to adjust the above code to get it right.
by adamr1 on Tue Oct 10, 2017 1:13 pm
Thanks for the reply. This makes sense but I just don't see how the r g b info is extracted to use in with the color888 function.
adamr1
by adafruit_support_rick on Tue Oct 10, 2017 1:29 pm
ledarray is a pointer to a uint32_t. I'm casting it to a pointer to a uint8_t. So, that means that the uint8_t pointer will access the four bytes of the uint32_t in order.
        uint8_t r = *arrayPtr++;  //gets the first byte of the uint32_t, and increments the uint8_t pointer
        uint8_t g = *arrayPtr++;  //gets the second byte of the uint32_t, and increments the uint8_t pointer
        uint8_t b = *arrayPtr++;  //gets the third byte of the uint32_t, and increments the uint8_t pointer
by adamr1 on Tue Oct 10, 2017 8:49 pm
Thanks, I get an error:
cast from 'const uint32_t* {aka const long unsigned int*}' to 'uint8_t {aka unsigned char}' loses precision
on the line
Any ideas?
Thank you!
adamr1
by adafruit_support_rick on Wed Oct 11, 2017 12:18 pm
D'Oh! Sorry. Typo. Should be casting to a (uint8_t*). Also, there's another typo in there - it should be *arrayPtr++; to skip the fourth byte
While I was looking at this, I realized that the array you're getting is assuming a different byte order for uint32_t than is used by the Arduino (if you're interested, look up the difference between "little-endian" and "big-endian")
Anyway, it means that you have to reverse the order of reading the bytes. The first byte you see will be the 00 that you want to ignore. The next byte will be blue, then green, then red:
  uint8_t *arrayPtr = (uint8_t*)ledarray;
        *arrayPtr++;  //skip 1st byte
        uint8_t b = *arrayPtr++;  //blue is second byte
        uint8_t g = *arrayPtr++;  //green is third byte
        uint8_t r = *arrayPtr++;  //red is fourth byte
