Repeating images in Supernova Poi
by DJ Namaste on Fri Nov 03, 2017 2:09 pm
Hello, I am trying to modify the supernova code to repeat images down the row of leds so there are multiple images over a long strip. I have it working but there is a flash of color after the image is displayed. Below is my modified code. In images.h file the NUM_LEDS definition is changed to the length of the strip and the code below specifies the height of the images to process.
case PALETTE1: { // 1-bit (2 color) palette-based image
uint8_t pixelNum = 0, byteNum, bitNum, pixels, idx,
*ptr = (uint8_t *)&imagePixels[imageLine * 32 / 8];
for(byteNum = 32/8; byteNum--; ) { // Always padded to next byte // or NUM_LEDS/8 instead of 32
pixels = *ptr++; // 8 pixels of data (pixel 0 = LSB)
for(bitNum = 8; bitNum--; pixels >>= 1) {
idx = pixels & 1; // Color table index for pixel (0 or 1)
strip.setPixelColor(pixelNum++,
palette[idx][0], palette[idx][1], palette[idx][2]);
break;
DJ Namaste
Re: Repeating images in Supernova Poi
by DJ Namaste on Sun Nov 12, 2017 1:20 am
Here is an example of what I am trying to do. The code repeats the test pattern down the strip of 160 leds. The pattern is a 32 pixel chase so it should continue down all the leds creating moving dots. There is a flash in between each display that I cant get rid of. The display rate is also slowed down for some reason which may be why there is the flash of random colors.
  POV IR Supernova Poi sketch.  Uses the following Adafruit parts
  (X2 for two poi):
  - Teensy 3.2 (required - NOT compatible w/AVR-based boards)
  - 2200 mAh Lithium Ion Battery https://www.adafruit.com/product/1781
  - LiPoly Backpack https://www.adafruit.com/product/2124
  - 144 LED/m DotStar strip (#2328 or #2329)
    (ONE METER is enough for TWO poi)
  - Infrared Sensor: https://www.adafruit.com/product/157
  - Mini Remote Control: https://www.adafruit.com/product/389
    (only one remote is required for multiple poi)
  Needs Adafruit_DotStar library: github.com/adafruit/Adafruit_DotStar
  Also, uses version of IRremote library from the Teensyduino installer,
  the stock IRremote lib will NOT work here!
  This is based on the LED poi code (also included in the repository),
  but AVR-specific code has been stripped out for brevity, since these
  mega-poi pretty much require a Teensy 3.X.
  products from Adafruit!
  Written by Phil Burgess / Paint Your Dragon for Adafruit Industries.
  MIT license, all text above must be included in any redistribution.
  See 'COPYING' file for additional notes.
#include <Arduino.h>
#include <Adafruit_DotStar.h>
#//include <avr/power.h>
#//include <avr/sleep.h>
#include <IRremote.h>
#include <SPI.h>
typedef uint16_t line_t;
// CONFIGURABLE STUFF ------------------------------------------------------
#include "graphics.h" // Graphics data is contained in this header file.
// It's generated using the 'convert.py' Python script.  Various image
// formats are supported, trading off color fidelity for PROGMEM space.
// Handles 1-, 4- and 8-bit-per-pixel palette-based images, plus 24-bit
// truecolor.  1- and 4-bit palettes can be altered in RAM while running
// to provide additional colors, but be mindful of peak & average current
// draw if you do that!  Power limiting is normally done in convert.py
// (keeps this code relatively small & fast).
// Ideally you use hardware SPI as it's much faster, though limited to
// specific pins.  If you really need to bitbang DotStar data & clock on
// different pins, optionally define those here:
#define LED_DATA_PIN  0
#define LED_CLOCK_PIN 2
#define pixelHeight 32
// Empty and full thresholds (millivolts) used for battery level display:
#define BATT_MIN_MV 3350 // Some headroom over battery cutoff near 2.9V
#define BATT_MAX_MV 4000 // And little below fresh-charged battery near 4.1V
boolean autoCycle = true; // Set to true to cycle images by default
uint32_t CYCLE_TIME = 4; // Time, in seconds, between auto-cycle images
int RECV_PIN = 4;
IRrecv irrecv(RECV_PIN);
decode_results results;
// Adafruit IR Remote Codes:
//   Button       Code         Button  Code
//   VOL-:        0xFD00FF     0/10+:  0xFD30CF
//   Play/Pause:  0xFD807F     1:      0xFD08F7
//   VOL+:        0xFD40BF     2:      0xFD8877
//   SETUP:       0xFD20DF     3:      0xFD48B7
//   STOP/MODE:   0xFD609F     4:      0xFD28D7
//   UP:          0xFDA05F     5:      0xFDA857
//   DOWN:        0xFDB04F     6:      0xFD6897
//   LEFT:        0xFD10EF     7:      0xFD18E7
//   RIGHT:       0xFD50AF     8:      0xFD9867
//   ENTER/SAVE:  0xFD906F     9:      0xFD58A7
//   Back:        0xFD708F
#define BTN_BRIGHT_UP    0xFD40BF
#define BTN_BRIGHT_DOWN  0xFD00FF
#define BTN_RESTART      0xFD807F
#define BTN_BATTERY      0xFD20DF
#define BTN_FASTER       0xFD805F
#define BTN_SLOWER       0xFDB04F
#define BTN_OFF          0xFD609F
#define BTN_PATTERN_PREV 0xFD10EF
#define BTN_PATTERN_NEXT 0xFD50AF
#define BTN_AUTOPLAY     0XFD906F
#define BTN_NONE         -1
#if defined(LED_DATA_PIN) && defined(LED_CLOCK_PIN)
// Older DotStar LEDs use GBR order.  If colors are wrong, edit here.
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS,
  LED_DATA_PIN, LED_CLOCK_PIN, DOTSTAR_BGR);
#else
Adafruit_DotStar strip = Adafruit_DotStar(NUM_LEDS, DOTSTAR_BGR);
#endif
void     imageInit(void),
         IRinterrupt(void);
uint16_t readVoltage(void);
  strip.begin(); // Allocate DotStar buffer, init SPI
  strip.clear(); // Make sure strip is clear
  strip.show();  // before measuring battery
  imageInit();   // Initialize pointers for default image
  irrecv.enableIRIn(); // Start the receiver
// GLOBAL STATE STUFF ------------------------------------------------------
uint32_t lastImageTime = 0L, // Time of last image change
         lastLineTime  = 0L;
uint8_t  imageNumber   = 0,  // Current image being displayed
         imageType,          // Image type: PALETTE[1,4,8] or TRUECOLOR
        *imagePalette,       // -> palette data in PROGMEM
        *imagePixels,        // -> pixel data in PROGMEM
         palette[16][3];     // RAM-based color table for 1- or 4-bit images
line_t   imageLines,         // Number of lines in active image
         imageLine;          // Current line number in image
volatile uint16_t irCode = BTN_NONE; // Last valid IR code received
const uint8_t PROGMEM brightness[] = { 15, 31, 63, 127, 255 };
uint8_t bLevel = sizeof(brightness) - 1;
// Microseconds per line for various speed settings
const uint16_t PROGMEM lineTable[] = { // 375 * 2^(n/3)
  1000000L /  375, // 375 lines/sec = slowest
  1000000L /  472,
  1000000L /  595,
  1000000L /  750, // 750 lines/sec = mid
  1000000L /  945,
  1000000L / 1191,
  1000000L / 1500  // 1500 lines/sec = fastest
uint8_t  lineIntervalIndex = 3;
uint16_t lineInterval      = 1000000L / 1500;
void imageInit() { // Initialize global image state for current imageNumber
  imageType    = images[imageNumber].type;
  imageLines   = images[imageNumber].lines;
  imageLine    = 0;
  imagePalette = (uint8_t *)images[imageNumber].palette;
  imagePixels  = (uint8_t *)images[imageNumber].pixels;
  // 1- and 4-bit images have their color palette loaded into RAM both for
  // faster access and to allow dynamic color changing.  Not done w/8-bit
  // because that would require inordinate RAM (328P could handle it, but
  // I'd rather keep the RAM free for other features in the future).
  if(imageType == PALETTE1)      memcpy_P(palette, imagePalette,  2 * 3);
  else if(imageType == PALETTE4) memcpy_P(palette, imagePalette, 16 * 3);
  lastImageTime = millis(); // Save time of image init for next auto-cycle
void nextImage(void) {
  if(++imageNumber >= NUM_IMAGES) imageNumber = 0;
  imageInit();
void prevImage(void) {
  imageNumber = imageNumber ? imageNumber - 1 : NUM_IMAGES - 1;
  imageInit();
// MAIN LOOP ---------------------------------------------------------------
  uint32_t t = millis(); // Current time, milliseconds
  if(autoCycle) {
    if((t - lastImageTime) >= (CYCLE_TIME * 1000L)) nextImage();
    // CPU clocks vary slightly; multiple poi won't stay in perfect sync.
    // Keep this in mind when using auto-cycle mode, you may want to cull
    // the image selection to avoid unintentional regrettable combinations.
  // Transfer one scanline from pixel data to LED strip:
  switch(imageType) {
              *ptr = (uint8_t *)&imagePixels[imageLine * pixelHeight / 8];
      for(byteNum = pixelHeight/8; byteNum--; ) { // Always padded to next byte
          strip.setPixelaColor(pixelNum++,
      break;
    case PALETTE4: { // 4-bit (16 color) palette-based image
      uint8_t  pixelNum, p1, p2, *ptr = (uint8_t *)&imagePixels[imageLine * pixelHeight / 2];
      for(pixelNum = 0; pixelNum < 32; ) {
        p2  = *ptr++;  // Data for two pixels...
        p1  = p2 >> 4; // Shift down 4 bits for first pixel
        p2 &= 0x0F;    // Mask out low 4 bits for second pixel
          palette[p1][0], palette[p1][1], palette[p1][2]);
          palette[p2][0], palette[p2][1], palette[p2][2]);
            for(pixelNum = 32; pixelNum < 64; ) {
                   for(pixelNum = 64; pixelNum < 98; ) {
                         for(pixelNum = 96; pixelNum < 128; ) {
                         for(pixelNum = 128; pixelNum < 160; ) {
      break;
    case PALETTE8: { // 8-bit (256 color) PROGMEM-palette-based image
      uint16_t  o;
      uint8_t   pixelNum,
               *ptr = (uint8_t *)&imagePixels[imageLine * pixelHeight];
      for(pixelNum = 0; pixelNum < 32; pixelNum++) {
        o = *ptr++ * 3; // Offset into imagePalette
        strip.setPixelColor(pixelNum,
          imagePalette[o],
          imagePalette[o + 1],
          imagePalette[o + 2]);
            for(pixelNum = 32; pixelNum < 64; pixelNum++) {
          imagePalette[o],
            for(pixelNum = 64; pixelNum < 96; pixelNum++) {
          imagePalette[o],
            for(pixelNum = 96; pixelNum < 128; pixelNum++) {
          imagePalette[o],
            for(pixelNum = 128; pixelNum < 160; pixelNum++) {
          imagePalette[o],
      break;
    case TRUECOLOR: { // 24-bit ('truecolor') image (no palette)
      uint8_t  pixelNum, r, g, b,
              *ptr = (uint8_t *)&imagePixels[imageLine * NUM_LEDS * 3];
      for(pixelNum = 0; pixelNum < NUM_LEDS; pixelNum++) {
        r = *ptr++;
        g = *ptr++;
        b = *ptr++;
        strip.setPixelColor(pixelNum, r, g, b);
      break;
  if(++imageLine >= imageLines) imageLine = 0; // Next scanline, wrap around
  IRinterrupt();
  while(((t = micros()) - lastLineTime) < lineInterval) {
    if(results.value != BTN_NONE) {
      if(!strip.getBrightness()) { // If strip is off...
        // Set brightness to last level
        strip.setBrightness(brightness[bLevel]);
        // and ignore button press (don't fall through)
        // effectively, first press is 'wake'
      } else {
        switch(results.value) {
         case BTN_BRIGHT_UP:
          if(bLevel < (sizeof(brightness) - 1))
            strip.setBrightness(brightness[++bLevel]);
          break;
         case BTN_BRIGHT_DOWN:
          if(bLevel)
            strip.setBrightness(brightness[--bLevel]);
          break;
         case BTN_FASTER:
          CYCLE_TIME++;
          if(lineIntervalIndex < (sizeof(lineTable) / sizeof(lineTable[0]) - 1))
           lineInterval = lineTable[++lineIntervalIndex];
          break;
         case BTN_SLOWER:
         if(CYCLE_TIME > 0) CYCLE_TIME--;
          if(lineIntervalIndex)
           lineInterval = lineTable[--lineIntervalIndex];
          break;
         case BTN_RESTART:
          imageNumber = 0;
          imageInit();
          break;
         case BTN_OFF:
          strip.setBrightness(0);
          break;
         case BTN_PATTERN_PREV:
          prevImage();
          break;
         case BTN_PATTERN_NEXT:
          nextImage();
          break;
         case BTN_AUTOPLAY:
          autoCycle = !autoCycle;
          break;
      results.value = BTN_NONE;
  strip.show(); // Refresh LEDs
  lastLineTime = t;
void IRinterrupt() {
  if (irrecv.decode(&results)) {
    Serial.println(results.value, HEX);
    irrecv.resume(); // Receive the next value
DJ Namaste
by DJ Namaste on Sun Nov 12, 2017 1:21 am
The graphics.h file
// Don't edit this file!  It's software-generated.
// See convert.py script instead.
#define PALETTE1  0
#define PALETTE4  1
#define PALETTE8  2
#define TRUECOLOR 3
#define NUM_LEDS 160
// /Users/Myshi/Desktop/test pic hoop/test pic256.gif ----------------------
const uint8_t PROGMEM palette00[][3] = {
  {   0,   0,   0 },
  {   0,   0, 250 },
  {   9,   0, 180 },
  {  89,   0, 250 },
  { 231,   0,   0 },
  { 125,   0, 180 },
  { 250,   0,  53 },
  {   0,   6, 250 },
  { 250,   0,  81 },
  { 250,   0,   0 },
  { 250,   0, 226 },
  { 250,   2,   0 },
  {   0,  33, 250 },
  { 250,  21,   0 },
  {   0,  74, 250 },
  { 250,  33,   0 },
  { 250,  89,   0 },
  {   0, 250,   0 },
  {   0, 250,  10 },
  {   0, 250,  15 },
  {   0, 212, 250 },
  {   0, 250,  60 },
  {   0, 250,  98 },
  {   0, 250, 159 },
  {  10, 250,   0 },
  { 250, 136,   0 },
  {  24, 250,   0 },
  {  98, 250,   0 },
  { 159, 250,   0 },
  { 226, 250,   0 } };
const uint8_t PROGMEM pixels00[] = {
  0X04, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X05, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X02, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X07, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X0E, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X17, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X15, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X12,
  0X1A, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X1C, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X19, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X0F, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X09, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X08, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X03, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X01,
  0X0C, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X14, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X16, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X13, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X11, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X18, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X1B, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X1D,
  0X10, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X0D, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X0B, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X0B, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X0A, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X0A, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X06, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X06 };
// /Users/Myshi/Desktop/test pic hoop/test pic16.gif -----------------------
const uint8_t PROGMEM palette01[][3] = {
  {   0,   0,   0 },
  {  35,   0, 255 },
  {   3,   2, 214 },
  { 255,   0,  62 },
  { 209,   0, 209 },
  { 247,   3,   0 },
  {   0,  32, 255 },
  {   0,  74, 255 },
  { 250,  58,   0 },
  {   0, 214, 252 },
  {   0, 252,  33 },
  {   5, 250,   1 },
  {   0, 252, 129 },
  { 252, 136,   0 },
  {  97, 252,   0 },
  { 193, 250,   0 } };
const uint8_t PROGMEM pixels01[] = {
  0X50, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X20, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X02, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X70, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X0C, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0XA0, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0XB0, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X0F, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0XD0, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X50, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X10,
  0X60, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X09, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0XC0, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X0A, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0XB0, 0X00, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0XE0, 0X00, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X80, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X05, 0X00, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X50, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X05, 0X00, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X40, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X04, 0X00,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X30,
  0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X00, 0X03 };
// /Users/Myshi/Desktop/test pic hoop/test pic2color.gif -------------------
const uint8_t PROGMEM palette02[][3] = {
  {   0,   0,   0 },
  { 155,  85,  30 } };
const uint8_t PROGMEM pixels02[] = {
  0X01, 0X00, 0X00, 0X00, 0X02, 0X00, 0X00, 0X00,
  0X04, 0X00, 0X00, 0X00, 0X08, 0X00, 0X00, 0X00,
  0X10, 0X00, 0X00, 0X00, 0X20, 0X00, 0X00, 0X00,
  0X40, 0X00, 0X00, 0X00, 0X80, 0X00, 0X00, 0X00,
  0X00, 0X01, 0X00, 0X00, 0X00, 0X02, 0X00, 0X00,
  0X00, 0X04, 0X00, 0X00, 0X00, 0X08, 0X00, 0X00,
  0X00, 0X10, 0X00, 0X00, 0X00, 0X20, 0X00, 0X00,
  0X00, 0X40, 0X00, 0X00, 0X00, 0X80, 0X00, 0X00,
  0X00, 0X00, 0X01, 0X00, 0X00, 0X00, 0X02, 0X00,
  0X00, 0X00, 0X04, 0X00, 0X00, 0X00, 0X08, 0X00,
  0X00, 0X00, 0X10, 0X00, 0X00, 0X00, 0X20, 0X00,
  0X00, 0X00, 0X40, 0X00, 0X00, 0X00, 0X80, 0X00,
  0X00, 0X00, 0X00, 0X01, 0X00, 0X00, 0X00, 0X02,
  0X00, 0X00, 0X00, 0X04, 0X00, 0X00, 0X00, 0X08,
  0X00, 0X00, 0X00, 0X10, 0X00, 0X00, 0X00, 0X20,
  0X00, 0X00, 0X00, 0X40, 0X00, 0X00, 0X00, 0X80 };
typedef struct {
  uint8_t        type;    // PALETTE[1,4,8] or TRUECOLOR
  line_t         lines;   // Length of image (in scanlines)
  const uint8_t *palette; // -> PROGMEM color table (NULL if truecolor)
  const uint8_t *pixels;  // -> Pixel data in PROGMEM
} image;
const image PROGMEM images[] = {
  { PALETTE8 ,   32, (const uint8_t *)palette00, pixels00 },
  { PALETTE4 ,   32, (const uint8_t *)palette01, pixels01 },
  { PALETTE1 ,   32, (const uint8_t *)palette02, pixels02 }
#define NUM_IMAGES (sizeof(images) / sizeof(images[0]))
DJ Namaste
