Analog LED Strip
Analog LED Strip
by kfrancsis on Mon Nov 06, 2017 2:35 pm
Could someone tell me why this is happening? Why when I connect my LED strip (part no. 285) with the solderless connectors (part no. 1004), the strips don't show the same colors? Also when I change the color with the RF Controller (part no. 678) each part of the strip reacts differently
kfrancsis
Re: Analog LED Strip
by franklin97355 on Wed Nov 08, 2017 12:54 pm
It looks like the connections on one side are not making full connections.
franklin97355
by kfrancsis on Wed Nov 08, 2017 1:49 pm
I don't think that is the issue. Because when I use the RF remote the two strips will switch colors. So if the left is white and the right is purple and I am on purple, when I move to white the left will be purple and the right will be white. I get all the colors. If it was a bad connection, I think I would be missing a color. This happens with different strips. All the connecting strips are cut from the middle of a 5 meter roll. The factory soldered ends follow the color wheel.
kfrancsis
