WS2812B vs. SK6812
WS2812B vs. SK6812
by jpcote on Tue Nov 07, 2017 9:03 pm
I'm using a library for Node.js called node-pixel (https://github.com/ajfisher/node-pixel) which supports WS2812B but does not seem to provide support for SK6812 (https://github.com/ajfisher/node-pixel/issues/73).
The problem is that most of the Neopixels sold on Adafruit come with the following mention: "May ship with either WS2812B or SK6812-based LEDs". How can I know if it's going to work?
I have used Neopixels successfully with this library but I bought them over a year ago. Now I'm not sure if what I receive will work with this module.
jpcote
Re: WS2812B vs. SK6812
by franklin97355 on Wed Nov 08, 2017 1:08 pm
I would check with the author of the library to see if the problem is resolved.
franklin97355
by jpcote on Wed Nov 08, 2017 1:14 pm
Yeah, I already sent him a message on Gitter but I have yet to receive an answer. Are those two chipsets similar? It's kind of odd to not know what we are getting when ordering...
jpcote
by franklin97355 on Wed Nov 08, 2017 2:26 pm
Our libraries work with both and they are similar. You can get specific pixels from other suppliers if you need a known type.
franklin97355
by jpcote on Wed Nov 08, 2017 2:33 pm
Okay, thanks.
My issue is that I'm using a third party library for which it is unclear if support exists for the SK6812 chipset (still waiting to hear from them...). I guess I'll have to buy from somewhere else if I manage to find an equivalent to your 60 pixel ring.
jpcote
by jpcote on Thu Nov 09, 2017 12:19 am
I had ordered RGB rings which I received today. It turns out that they are working with the node-pixel library. I don't know if I received WS2812 or SK6812 though. Is there a way to know?
jpcote
by Arudinne on Sun Nov 12, 2017 2:54 pm
jpcote wrote:I had ordered RGB rings which I received today. It turns out that they are working with the node-pixel library. I don't know if I received WS2812 or SK6812 though. Is there a way to know?
You might be able to tell by a visual inspection but there's no guarantee that will be a reliable indicator. The SK6812 is supposed to be a clone of the WS2812B, but there are some reports that it's actually better than the original.
Any code that works for the WS2812B should work on the SK6812.
https://cpldcpu.com/2016/03/09/the-sk68 ... t-rgb-led/
https://hackaday.com/2017/01/25/ws2812b ... originals/
https://talk.vanhack.ca/t/psa-ws2812b-l ... y-are/5626
Arudinne
by jpcote on Sun Nov 12, 2017 5:09 pm
This issue on GitHub https://github.com/ajfisher/node-pixel/issues/73 made me question whether WS2812b and SK6812 are indeed equivalent. But, from my own tests, they seem to work just the same. Thanks for your feedback.
jpcote
by Arudinne on Sun Nov 12, 2017 9:44 pm
jpcote wrote:This issue on GitHub https://github.com/ajfisher/node-pixel/issues/73 made me question whether WS2812b and SK6812 are indeed equivalent. But, from my own tests, they seem to work just the same. Thanks for your feedback.
That's a slightly different issue. There are RGB addressable LEDs and RGBW addressable LEDs. They are similar but the RGBW LEDs require an extra 8 bit value for the W portion of the LED IIRC.
Arudinne
by jpcote on Sun Nov 12, 2017 9:58 pm
The GitHub issue is titled "Add support for SK6812". The author of the library says: "As these are starting to become more available and are largely the same as the WS2812, add direct support for these by being able to shift a little faster on the HIs." At this point, he is talking about SK6812-based LEDs.
Then, some 9 months later, somebody else mentions RGBW which, as you mentioned, is another story.
A few days ago, the author of the library said this on Gitter regarding SK6812: "Regarding SK6812 - I don't have any of these to test with however the protocol is largely the same so it should work. If it doesn't it will be relatively straightforward to implement."
jpcote
by Arudinne on Sun Nov 12, 2017 11:36 pm
Ah. I misread it because I saw the RGBW part.
Arudinne
