Clear TFT Display
ADAD_d
Clear TFT Display
Post by ADAD_d »
Hi there,
I am using the 1.44 Inch TFT display from Adafruit and I was wondering if there was any way to clear a display without using the fillScreen method?
Thanks.
adafruit_support_carter
Re: Clear TFT Display
I think that's it for the GFX library:
https://learn.adafruit.com/adafruit-gfx ... the-screen
You might be able to use something from the lower level ST7735 library:
https://github.com/adafruit/Adafruit-ST7735-Library
But why do you have an issue using fillScreen?
ADAD_d
Post by ADAD_d »
That function is too slow. I need to rapidly update the screen.
Try taking a look at how this is done in this project:
https://learn.adafruit.com/animated-ele ... 1/software
There's a lot to it, but it does show how it's at least possible.
seckindogan
Post by seckindogan »
ddesousa wrote:That function is too slow. I need to rapidly update the screen.
I have the same issue. Did you find a solution ?
Or does anyone knows is there a something like like tft.clear(); ?
seckindogan
I found a solution here ; https://github.com/adafruit/Adafruit-GF ... /issues/16
Simply write tft.setTextColor(ST7735_RED, ST7735_BLACK); before the tft.print.
 tft.setTextSize(2);
 tft.setCursor(10,50);
 tft.print(t);
