Neopixel Throughhole Not Showing Yellow
by Duffyhaha on Fri Nov 17, 2017 11:51 pm
H have a project that i am building using the 8mm through-hole pixels and noticed that they are not showing some colors. For example, the RED (255,0,0) shows fine on a test strip of 4, but if I try PINK(255, 128, 0) only the 3rd will show and the others are black.
I can get them all to show RED, BLUE, GREEN and ORANGE (255, 128, 0) though.
I have a D-Cell battery 3 pack powering the pixels on their own and a 1000uf cap in the power rail before the pixels. Additionally, i have a 10K resistor in front of the data line but i tried with a 330 and that didnt make a difference.
Not sure what i am doing wrong...
Duffyhaha
Re: Neopixel Throughhole Not Showing Yellow
by franklin97355 on Fri Nov 17, 2017 11:58 pm
Post your code and pictures of your circuit. The pixels only have red, green, and blue LEDs so if you can get those colors they are working.
franklin97355
by Duffyhaha on Sat Nov 18, 2017 12:05 am
Thanks for the quick reply! I dont have my phone with me now for a picture of the circuit though.
Adafruit_NeoPixel strip1 = Adafruit_NeoPixel(4, 8, NEO_RGB + NEO_KHZ800); //Zone 1 Light Strip
//define colors
uint32_t magenta = strip1.Color(255, 0, 255);
uint32_t red = strip1.Color(255, 0, 0);
uint32_t green = strip1.Color(0, 255, 0);
uint32_t blue = strip1.Color(0, 0, 255);
//uint32_t yellow = strip1.Color(255, 255, 0);
uint32_t yellow = strip1.Color(100, 100, 0);
uint32_t pink = strip1.Color(240, 51, 240);
uint32_t orange = strip1.Color(255, 128, 0);
void setup()
  Serial.begin(9600); //setup serial monitor
  strip1.begin();
  strip1.show(); // Initialize all pixels to 'off'
  colorFill(pink, &strip1);
void loop()
  //empty for now....
// Fill the dots one after the other with a color
void colorFill(uint32_t c, Adafruit_NeoPixel *s) {
  for (uint16_t i = 0; i < s->numPixels(); i++) {
    s->setPixelColor(i, c);
  delay(10);
  s->show();
Duffyhaha
by Duffyhaha on Sat Nov 18, 2017 12:07 am
One other thing i just noticed is that all 4 lights flash PINK for a second and then all but the third (index 2) turn off.
Duffyhaha
by Duffyhaha on Fri Dec 01, 2017 5:53 pm
Wanted to let everyone know that I was able to fix the issue.
I looked at the documentation for the chip and noticed the capacitor used between ground and the 5v pins.
I added capacitors for each pixel and they work properly now!
Duffyhaha
