Micro SD Card Problems on TFT Touchscreen
by amarch on Mon Nov 27, 2017 4:06 pm
I had purchased about 100 of Adafruit's 3.5" TFT touchscreens.
I had a few before but wasn't able to pinpoint the issue until I had more. Some of my prototypes had trouble starting the SPI connection to the SD card. After testing it with more units and different kinds of SD cards, I have concluded that there is an issue with the SD card holder/mechanism. On some screens, it will not read the SD card I put in (even though the same SD card will work on other screens). Sometimes I can hear an audible short happening when I attempt to initialize the SD card in the firmware - it creates a high-pitched whine from the SD card holder and intensifies if I press down on the holder.
I am experiencing this problem with about 20% of the screens that I was shipped (and one of the screens was cracked out of the box)!
Do you have protocols for fixing the micro SD card holder? Furthermore, a lot of SD cards (Sandisk, Samsung, Kingston) simply have problems reading. I have some experience with micro SD card holders and these spring loaded ones that are on the screens really suck. But since they are already there, what do you suggest I do to salvage the units that I already have?
Thank you for your help!
amarch
Re: Micro SD Card Problems on TFT Touchscreen
by amarch on Sun Dec 03, 2017 10:40 pm
Any follow-up to this question? Short of replacing the actual micro SD devices, I am not sure what to do. This is some very poor manufacturing QA/QC!
amarch
by ytan on Thu May 03, 2018 6:08 am
Facing the same problem here using Arduino Due.
I was able to use the microSD and also the Display separately, but when together the microSD reader fails. Could this be a power issue? In any case, I'll try again with an Arduino Mega 2560 to see if the problem persists. : /
ytan
by ytan on Fri May 04, 2018 3:53 am
Update:
Bought a brand new 16GB Sandisk Ultra microSDHC UHS-I microSD, and now it's working.
My earlier card was 32GB with a 4GB partition.
Hm... not sure what to make of this. Maybe it's an issue with the volume?
ytan
