Lens for WS2812 neopixel
by TheElementronics on Tue Nov 28, 2017 6:01 pm
Hi guys
I bought a lens for my RGB neopixel, in hope that i can create a DIY moving head. That lens transforme the source light into a lightbeam with 10 degree angle.
The problem is Snell´s Law, and more directly the different wavelenght of RGB.
If the led is red/blue/green I get one red/blue/green lightbeam, but when I try to mix R/G/B I get 3 separated lightbeams, and that is not what I want.
EXAMPLE:
WHITE = (R,G,B)=(255,255,255)
Images
AND I WANNA GET SOMETHING LIKE THIS
TheElementronics
Re: Lens for WS2812 neopixel
by franklin97355 on Tue Nov 28, 2017 6:31 pm
The WS2812 is three separate LEDs in one case so if you focus that you will see three colored dots. You need to diffuse the beam before focusing it.
franklin97355
by TheElementronics on Tue Nov 28, 2017 8:16 pm
franklin97355 wrote:The WS2812 is three separate LEDs in one case so if you focus that you will see three colored dots. You need to diffuse the beam before focusing it.
My concern is, diffusing the light I will loss brightness right?
TheElementronics
by franklin97355 on Tue Nov 28, 2017 8:42 pm
You will lose some, yes.
franklin97355
by TheElementronics on Wed Nov 29, 2017 1:09 pm
franklin97355 wrote:You will lose some, yes.
Thank you
Do you know if exists diffusing lens for ws2812, I bought a lens on eBay, but is a refracting 10degree lens
I also search for diffusing methods, but I think that a lens will work better
TheElementronics
by adafruit_support_bill on Wed Nov 29, 2017 1:18 pm
You could try adding a layer of diffusion film between the led and the lens. You can find this at sign shops and plastics suppliers. However, given the short distances involved, you are not likely to get perfect mixing of the light from the 3 colored elements.
If you are looking for white light, you would be better off starting with a white LED instead of RGB.
by TheElementronics on Wed Nov 29, 2017 9:11 pm
adafruit_support_bill wrote:You could try adding a layer of diffusion film between the led and the lens. You can find this at sign shops and plastics suppliers. However, given the short distances involved, you are not likely to get perfect mixing of the light from the 3 colored elements.
Thank you
I´m looking for a RGB, that´s the goal
TheElementronics
by rexhex on Sat Mar 03, 2018 7:31 pm
also you could add some optical gel to reduce light loss out of the sides. I am also trying to find the right optics for these types of leds without much luck. However I am apart of a group on facebook called LEDs are Awesome, which is a lame name, but is also a good group. Anyways I posed the question and received that info. It makes sense that the led would need to be diffused as it always seems to need to be diffused. maybe some optic gel mixed with something lightly creamy? I have yet to look up optic gel, possibly there is a type with diffusion properties.
rexhex
by TheElementronics on Wed Apr 04, 2018 4:56 pm
rexhex wrote:also you could add some optical gel to reduce light loss out of the sides. I am also trying to find the right optics for these types of leds without much luck. However I am apart of a group on facebook called LEDs are Awesome, which is a lame name, but is also a good group. Anyways I posed the question and received that info. It makes sense that the led would need to be diffused as it always seems to need to be diffused. maybe some optic gel mixed with something lightly creamy? I have yet to look up optic gel, possibly there is a type with diffusion properties.
Thank you very much
I'll do a search for that optical gel and soon I'll say something
TheElementronics
