TroubleShooting with RGBW stips
by qfgh on Fri Dec 08, 2017 11:31 am
I work on a microcontroller by Microchip (PIC32MX) to control RGBW strip.
When I put 255 on blue component, the RGBW Strip displays an intensity blue-white . But when I put 255 on red or green or white component, the strip displays correctly the color.
Is this phenomenon found is normal?
qfgh
Re: TroubleShooting with RGBW stips
by adafruit_support_bill on Fri Dec 08, 2017 11:38 am
The 4 LEDs on the chip are individually controllable. You should be able to control blue independently from white.
by qfgh on Fri Dec 08, 2017 11:49 am
How to control blue indepently by white with my config:
T0H=355ns
T0L=2.238µs
T1H=613ns
T1L=2.399µs
qfgh
by adafruit_support_bill on Fri Dec 08, 2017 11:58 am
I'm not familiar with the processor or code you are using. Our Neopixel library supports all of the Arduino and compatible processors.
by qfgh on Mon Dec 11, 2017 3:47 am
Is it possible to control only blue color without white color?
When I control blue, I have a blue-white color appear on RGBW Strip.
qfgh
by adafruit_support_bill on Mon Dec 11, 2017 7:35 am
RGBW strips take 4 bytes per pixel. One each for red, green, blue and white. Each is independently controllable.
https://learn.adafruit.com/adafruit-neo ... ibrary-use
strip.setPixelColor(n, red, green, blue, white);
by Disciple on Tue Dec 12, 2017 3:10 pm
There's another phenomenon that might be happening. I've noticed it in my RGBW's.
RGBW strip color issues
Hallelujah!
Disciple
Disciple
