Crush test / driveway safety
by randomdude1234 on Mon Dec 11, 2017 11:50 pm
I'm considering placing a few of the neopixels strips (the outdoor version) at ground level on my driveway at the very edge. However, I am concerned that there might be a time (or three) when someone in the family inadvertently drives over them (its happened to other lights) when pulling out and turning.
How resistant are these to being run over by a car? Has any one tried this? :)
Are they just going to get crushed? (ok) vs there being a risk of the strip catching fire (bad)?
randomdude1234
Re: Crush test / driveway safety
by franklin97355 on Tue Dec 12, 2017 12:57 am
With a proper power supply, you should have no worries about fire. You could add a fuse if you are worried.
franklin97355
by adafruit_support_bill on Tue Dec 12, 2017 6:51 am
They may well get crushed. I'd expect some broken solder joints. They do make aluminum channels designed to hold LED strips. That would give the strip a little more protection.
by randomdude1234 on Tue Dec 12, 2017 10:39 pm
Thanks! I'll look at aluminum channels and into adding a fuse into the loop
randomdude1234
