871 8x8 Matrix Backpack Errors
by parasbuy22 on Fri Dec 29, 2017 12:33 pm
Hi! I've been trying to get the 871 8x8 Matrix working but can't figure out why I can't get it to compile. I've installed the GFX library and the LED_backpack library in my /Arduino/libraries folder; and when I click Upload, I get the below error messages come up. Would you direct me to what I am doing wrong?
Thank you.
Paras.
Error Messages:
Arduino: nightly (Mac OS X), Board: "Arduino Uno"
Using library Wire in folder: /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire (legacy)
Using library Adafruit GFX Library in folder: /Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX
Using library Adafruit LED Backpack Library in folder: /Users/Nathan/Documents/Arduino/libraries/Adafruit_LED_Backpack
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=155 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/variants/standard -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_LED_Backpack /var/folders/wb/b2_cbqfj60l3s4frzs7q_7k00000gn/T/build416670684340017530.tmp/matrix8x8.cpp -o /var/folders/wb/b2_cbqfj60l3s4frzs7q_7k00000gn/T/build416670684340017530.tmp/matrix8x8.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=155 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/variants/standard -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_LED_Backpack -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire/utility /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire/Wire.cpp -o /var/folders/wb/b2_cbqfj60l3s4frzs7q_7k00000gn/T/build416670684340017530.tmp/Wire/Wire.cpp.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=155 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/variants/standard -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_LED_Backpack -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire/utility /Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire/utility/twi.c -o /var/folders/wb/b2_cbqfj60l3s4frzs7q_7k00000gn/T/build416670684340017530.tmp/Wire/utility/twi.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=155 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/variants/standard -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_LED_Backpack -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/utility /Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/glcdfont.c -o /var/folders/wb/b2_cbqfj60l3s4frzs7q_7k00000gn/T/build416670684340017530.tmp/Adafruit GFX Library/glcdfont.c.o
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=155 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/cores/arduino -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/variants/standard -I/Applications/Arduino.app/Contents/Resources/Java/hardware/arduino/avr/libraries/Wire -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_LED_Backpack -I/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/utility /Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/Adafruit_SPITFT.cpp -o /var/folders/wb/b2_cbqfj60l3s4frzs7q_7k00000gn/T/build416670684340017530.tmp/Adafruit GFX Library/Adafruit_SPITFT.cpp.o
/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/Adafruit_SPITFT.cpp: In member function 'void Adafruit_SPITFT::initSPI(uint32_t)':
/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/Adafruit_SPITFT.cpp:112: error: 'SPI' was not declared in this scope
/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/Adafruit_SPITFT.cpp: In member function 'virtual void Adafruit_SPITFT::startWrite()':
/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/Adafruit_SPITFT.cpp:167: error: 'SPI' was not declared in this scope
/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/Adafruit_SPITFT.cpp:167: error: 'SPI_CLOCK_DIV2' was not declared in this scope
/Users/Nathan/Documents/Arduino/libraries/Adafruit_GFX/Adafruit_SPITFT.cpp:167: error: 'SPI_MODE0' was not declared in this scope
Exception in thread "AWT-EventQueue-0" java.lang.RuntimeException: Non-Java exception raised, not handled! (Original problem: Deprecated in 10_12... DO NOT EVER USE CGSEventRecord directly. Bad things, man.... bad things.)
   at apple.awt.ComponentModel._handleEvent(Native Method)
   at apple.awt.ComponentModel.handleEvent(ComponentModel.java:273)
   at apple.awt.CWindow.handleEvent(CWindow.java:545)
   at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:753)
   at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1000)
   at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:865)
   at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:686)
   at java.awt.Component.dispatchEventImpl(Component.java:4648)
   at java.awt.Container.dispatchEventImpl(Container.java:2142)
   at java.awt.Window.dispatchEventImpl(Window.java:2492)
   at java.awt.Component.dispatchEvent(Component.java:4604)
   at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:717)
   at java.awt.EventQueue.access$400(EventQueue.java:82)
   at java.awt.EventQueue$2.run(EventQueue.java:676)
   at java.awt.EventQueue$2.run(EventQueue.java:674)
   at java.security.AccessController.doPrivileged(Native Method)
   at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:86)
   at java.security.AccessControlContext$1.doIntersectionPrivilege(AccessControlContext.java:97)
   at java.awt.EventQueue$3.run(EventQueue.java:690)
   at java.awt.EventQueue$3.run(EventQueue.java:688)
   at java.awt.EventQueue.dispatchEvent(EventQueue.java:687)
   at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:296)
   at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:211)
   at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:201)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:196)
   at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:188)
   at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
parasbuy22
Re: 871 8x8 Matrix Backpack Errors
by parasbuy22 on Wed Jan 03, 2018 8:06 pm
Hi... thought I'd check in to see if there would be a response coming?
Thank you.
Paras.
parasbuy22
