difficulty coding adafruit neopixel flashing dynamic car
by guigui81 on Tue Jan 02, 2018 4:55 pm
Good evening to the community,
To begin, Happy New Year to you all!
I just discovered the beautiful world of adafruit and arduino a few weeks ago.
I can do some DIY but I'm far from what I'm trying to do!
Could someone please help me.
I want to use my neopixel RGB led strip to create a car flashing scroll like these videos.
https://youtu.be/K_3U41Ok7dc
or: https://youtu.be/CqiLsHXxZKg
For the installation in the lighthouse and arduino everything is OK, my problem is on the code.
I tried to edit with the available libraries but I can not do it.
I have 22 LEDs on each side and the flashing lights up with the + steering wheel or warnng.
Thank you very much for your help, good evening
guigui81
Re: difficulty coding adafruit neopixel flashing dynamic car
by adafruit_support_bill on Tue Jan 02, 2018 5:22 pm
The strandtest example code includes a function called "colorWipe":
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
The first parameter is the color. For yellow, use "strip.Color(255, 255, 0)"
The second parameter is the speed. Use a number between 0 (fast) and 255 (slow) and adjust to get the speed that you need.
by guigui81 on Tue Jan 02, 2018 6:49 pm
Thank you for the answer but I try and I do not understand!
I think I'm missing too much base to get there: ((
I've followed a lot of tutorials to understand but I can not do it
I will start again tomorrow at rest
guigui81
by adafruit_support_bill on Tue Jan 02, 2018 9:32 pm
The pattern you are looking for is a simple loop, with a colorWipe in yellow followed by a colorWipe with black. Just keep repeating for the flashing effect.
by guigui81 on Thu Jan 04, 2018 10:11 am
Thank you.
The effect is good but it does not loop.
Why ?
Thank you for your help and patience!
#ifdef __AVR__
  #include <avr/power.h>
#endif
#define PIN 2
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, PIN, NEO_GRB + NEO_KHZ800);
  #if defined (__AVR_ATtiny85__)
    if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
  #endif
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
void loop()
  colorWipe(strip.Color(255, 255, 0), 30);
    strip.show();
    delay(25);
guigui81
by adafruit_support_bill on Thu Jan 04, 2018 10:17 am
You are only doing the colorWipe to yellow. You need to follow that with a colorWipe to black:
void loop()
  colorWipe(strip.Color(255, 255, 0), 30);  // yellow
  colorWipe(strip.Color(0, 0, 0), 30);  // black
by guigui81 on Thu Jan 04, 2018 1:16 pm
it works !!! :))) Thank you very much !
guigui81
by guigui81 on Thu Jan 04, 2018 1:36 pm
and do you know if I can increase the power of LEDs ?
guigui81
by adafruit_support_bill on Thu Jan 04, 2018 1:50 pm
No. 255 per channel is the maximum. If you want it to be brighter, you need to use higher power LEDs like the Pixies: https://www.adafruit.com/product/2741
