Hi there,
I have recently received this and am running the sample tftpaint sketch with a Mega 2560.
My issue is the touchscreen seems to be mirrored around the center of the screen.
If I swipe from left to right, the paint draws from right to left.
If I move my finger down, the paint draws upwards.
I cannot for the life of me figure out how to solve this-Im an arduino newbie.
If i physically swap the Xp Xm and Yp Ym pins on the mega it works as it should but I imagine this is not a good solution.
Changing the mapping of the pins in the sketch results in the touchscreen not working.
Any help or advice is sincerely appreciated.
Thank you.
3.5" TFT 320x480 + Touchscreen HXD8357D
- jamesobrady
Re: 3.5" TFT 320x480 + Touchscreen HXD8357D
I found a solution to my issue here:
In the code if I change this:
to this:
It works as expected.
p.x = map(p.x, TS_MINX, TS_MAXX, tft.width(), 0);
p.y = map(p.y, TS_MINY, TS_MAXY, tft.height(), 0);
p.x = map(p.x, TS_MAXX, TS_MINX, tft.width(), 0);
p.y = map(p.y, TS_MAXY, TS_MINY, tft.height(), 0);
