LED Matrix Display Not turning on
by majoshi1 on Sat Jan 13, 2018 8:42 pm
I am new to raspberry pi.
I am trying to setup the Pi 3 with LED Matrix display.
I ordered and got following accessories (Order Confirmation No: 1632430-0694356359):
1 x 5V 10A switching power supply[ID:658]
1 x 64x32 RGB LED Matrix - 6mm pitch[ID:2276]
Also, I am using Pi Hat.
And did the setup as per following article:
https://learn.adafruit.com/raspberry-pi ... y/overview
I can connect to Pi.
However, display is not turning ON, when I run the test.
Any idea?
Attaching details of my setup.
Please get back in case of any questions.
$ sudo ./display-test matrix.cfg
Using config values:
display_width: 64
display_height: 32
panel_width: 32
panel_height: 16
chain_length: 4
parallel_count: 1
grid rows: 2
grid cols: 2
Press Ctrl-C to quit...
Display Test
Front of Display
Back of Display and closeup of Pi and Hat
majoshi1
Re: LED Matrix Display Not turning on
by israeliov on Thu Feb 01, 2018 6:07 pm
hello majoshi1, i have just the same problem, everry thing works just fine i even made the tutorial https://learn.adafruit.com/adafruit-rgb ... spberry-pi and all the demos works great, but whe i tried to meke the matrix display tutorial, the panels do not turn on, please if you did fix the problem, help me.
israeliov
by swemoney on Sun Feb 04, 2018 7:43 am
Also having this issue. Have tried 2 different adafruit rgb hats. Using a raspberry pi 3. Tried the demos from the rpi-rgb-led-matrix repo as well as the rpi-fb-matrix repo. Can't get anything to display. Thinking the matrix is defective?
swemoney
by israeliov on Mon Feb 05, 2018 1:12 am
hi, swemoney
seems like you having much more problems, i keep looking for a solution, but mean wile at least try this guides, https://learn.adafruit.com/32x16-32x32- ... x?view=all, they use arduino, and is way much easier to use, at least that way you can chekc, if yours matrix work!!!
israeliov
by israeliov on Tue Feb 06, 2018 2:11 pm
Hi guys, i have some good news, finally can made the matrix work, the code is all right, my problem was the soldering on the HAT, apparently some points were not making the right contact, so check your HAT and make shure it is all nicely soldered.
greetings!!!
israeliov
by swemoney on Wed Feb 07, 2018 4:47 am
Also received a reply from support on my own thread about this and it turns out they sent me a cable that was backwards on one end so I have to flip the cable backwards on one side to get it to work.
swemoney
