32x32 ColorWheel Arduino example for LED board
- adafruit2
Re: 32x32 ColorWheel Arduino example for LED board
yah unclear! do you by chance have the packaging still that it came in? that might help - there should be a part # and maybe a revision code on there
- Fiona
Yes I still have the bag it came in. There's a sticker on it which says:
COM-12584 SF
RGB LED Panel - 32x32
Batch# 100946
Thanks for looking into this!
COM-12584 SF
Batch# 100946
- adafruit2
COM-12584 SF means its from Sparkfun https://www.sparkfun.com/products/12584 not adafruit :)
they defintiely have customer support, and can help you out there
thank you!
thank you!
- Fiona
Oh thank you so much! Sorry about all the trouble and thank you for directing me to the right place.
And thanks to adafruit_support_carter for all the time going through the wiring with me.
All the best!
All the best!
- tarbear123
everytime i go to upload it to the arduino nano, i get
Arduino: 1.8.6 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 11878 bytes (38%) of program storage space. Maximum is 30720 bytes.
Global variables use 303 bytes (14%) of dynamic memory, leaving 1745 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
Invalid library found in C:\Users\taran\Documents\Arduino\libraries\keypad_values: C:\Users\taran\Documents\Arduino\libraries\keypad_values
Invalid library found in C:\Users\taran\Documents\Arduino\libraries\Yahzee: C:\Users\taran\Documents\Arduino\libraries\Yahzee
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xdd
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xdd
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
- adafruit2
please contact the vendor you purxhased the nano from. this has nothing to do with the 32x32 led. thankx!
