Neopixel Strip DOA
Neopixel Strip DOA
by tracy0 on Fri Feb 02, 2018 1:14 pm
I got a Adafruit NeoPixel Digital RGBW LED Strip - Black PCB 30 LED/m about 3 weeks ago. I am using it with a Trinket 5v. The neopixel strip never worked. I followed your Neopixel Uberguide and nothing seems to work. I have also checked that all the wiring is correct and it seems so. I am guessing the strip is broken. Any ideas? Here are some pictures (sorry if they are blurry) and the code I am using:
#ifdef __AVR__
  #include <avr/power.h>
#endif
#define PIN 1
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
//   NEO_RGBW    Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(30, PIN, NEO_RGBW + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel's data input
// and minimize distance between Arduino and first pixel.  Avoid connecting
// on a live circuit...if you must, connect GND first.
  // This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
  #if defined (__AVR_ATtiny85__)
    if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
  #endif
  // End of trinket special code
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
  // Some example procedures showing how to display to the pixels:
  colorWipe(strip.Color(255, 0, 0), 50); // Red
  colorWipe(strip.Color(0, 255, 0), 50); // Green
  colorWipe(strip.Color(0, 0, 255), 50); // Blue
//colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
  // Send a theater pixel chase in...
  theaterChase(strip.Color(127, 127, 127), 50); // White
  theaterChase(strip.Color(127, 0, 0), 50); // Red
  theaterChase(strip.Color(0, 0, 127), 50); // Blue
  rainbow(20);
  rainbowCycle(20);
  theaterChaseRainbow(50);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
  for(uint16_t i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i, c);
    strip.show();
    delay(wait);
void rainbow(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256; j++) {
    for(i=0; i<strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel((i+j) & 255));
    strip.show();
    delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
  uint16_t i, j;
  for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
    for(i=0; i< strip.numPixels(); i++) {
      strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
    strip.show();
    delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
    for (int q=0; q < 3; q++) {
      for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
tracy0
Re: Neopixel Strip DOA
by adafruit_support_carter on Mon Feb 05, 2018 2:26 pm
What are you using for a power supply into the NeoPixel strip? Also, I can't fully see how the wires go from the Trinket to the strip. Can you post another photo of that.
by tracy0 on Mon Feb 05, 2018 5:38 pm
Sure. I am using a 5v 2amp power supply. Here are the additional pictures:
tracy0
by adafruit_support_carter on Mon Feb 05, 2018 7:49 pm
That all seems fine. Do you have a multimeter? If so, measure the voltage on the screw terminals of the barrel adapter for your power input. Let's make sure there's 5V there.
by tracy0 on Mon Feb 05, 2018 8:15 pm
The multimeter says 5.25 volts. By the way, thanks for the quick reply.
tracy0
by adafruit_support_carter on Mon Feb 05, 2018 9:37 pm
Hmmm. Do we know the Trinket is OK? Does it seem like everything is uploading to it fine? If you upload the basic blink test (for the onboard LED) does it work?
by tracy0 on Mon Feb 05, 2018 11:04 pm
Yes, I tried the blink test with a yellow LED via pin 1 and it worked.
tracy0
by adafruit_support_carter on Tue Feb 06, 2018 1:52 pm
This looks correct, but it's a little out of focus. Is the arrow on the strip pointing like this?
by tracy0 on Tue Feb 06, 2018 10:12 pm
Yes it is.
tracy0
by adafruit_support_carter on Wed Feb 07, 2018 12:44 pm
Let's replace it. Send an email to support@adafruit.com with a link to this thread and your order number and they can get you a replacement NeoPixel Digital RGBW LED Strip - Black PCB 30 LED/m.
by tracy0 on Wed Feb 07, 2018 5:04 pm
Thanks so much for the help!!!
tracy0
