PiTFT White Screen of Death
by sguttmann on Sat Feb 03, 2018 11:57 am
I recently purchased the Pigrrl Zero kit from Adafruit which included the Pi Zero and PiTFT. After assembling all the components following the Adafruit tutorial, I powered up the Pi with the image provided by Adafruit which supports the screen (https://adafruit-download.s3.amazonaws. ... 160912.zip) but all I get is the white screen. The green light on the Pi is blinking so it seems that its doing something. I have also tried different images with no luck. I am attaching some images of my soldering joints since I am not too proficient in soldering. Any comments or suggestions are appreciated.
Steve
sguttmann
Re: PiTFT White Screen of Death
by sguttmann on Sun Feb 04, 2018 12:33 am
Also, I have attached the dmesg.txt for your review. Thanks.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.35+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #1014 Fri Jun 30 14:34:49 BST 2017
[    0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[    0.000000] OF: fdt:Machine model: Raspberry Pi Zero W Rev 1.1
[    0.000000] cma: Reserved 8 MiB at 0x0f400000
[    0.000000] Memory policy: Data cache writeback
[    0.000000] On node 0 totalpages: 65536
[    0.000000] free_area_init_node: node 0, pgdat c0914874, node_mem_map cfdabc00
[    0.000000]   Normal zone: 576 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 65536 pages, LIFO batch:15
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 64960
[    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=320 bcm2708_fb.fbheight=240 bcm2708_fb.fbswap=1 smsc95xx.macaddr=B8:27:EB:80:25:D4 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=3d24ca30-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait loglevel=3 consoleblank=0 plymouth.enable=0
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 241256K/262144K available (5946K kernel code, 489K rwdata, 1948K rodata, 400K init, 734K bss, 12696K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xd0800000 - 0xff800000   ( 752 MB)
    lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
    modules : 0xbf000000 - 0xc0000000   (  16 MB)
      .text : 0xc0008000 - 0xc05d6bbc   (5947 kB)
      .init : 0xc0840000 - 0xc08a4000   ( 400 kB)
      .data : 0xc08a4000 - 0xc091e728   ( 490 kB)
       .bss : 0xc091e728 - 0xc09d5f28   ( 734 kB)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000030] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[    0.000061] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[    0.000155] bcm2835: system timer (irq = 27)
[    0.000614] Console: colour dummy device 80x30
[    0.000637] console [tty1] enabled
[    0.000661] Calibrating delay loop... 697.95 BogoMIPS (lpj=3489792)
[    0.060305] pid_max: default: 32768 minimum: 301
[    0.060729] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060746] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.061800] Disabling cpuset control group subsystem
[    0.062004] CPU: Testing write buffer coherency: ok
[    0.062061] ftrace: allocating 21712 entries in 64 pages
[    0.176874] Setting up static identity map for 0x8200 - 0x8238
[    0.178815] devtmpfs: initialized
[    0.188247] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[    0.188671] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.188697] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.189974] pinctrl core: initialized pinctrl subsystem
[    0.191421] NET: Registered protocol family 16
[    0.193915] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.203694] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[    0.203710] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.203813] Serial: AMBA PL011 UART driver
[    0.206687] bcm2835-mbox 2000b880.mailbox: mailbox enabled
[    0.207392] uart-pl011 20201000.serial: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[    0.256012] bcm2835-dma 20007000.dma: DMA legacy API manager at d080d000, dmachans=0x1
[    0.258781] SCSI subsystem initialized
[    0.259055] usbcore: registered new interface driver usbfs
[    0.259174] usbcore: registered new interface driver hub
[    0.259363] usbcore: registered new device driver usb
[    0.266943] raspberrypi-firmware soc:firmware: Attached to firmware from 2017-07-03 14:16
[    0.268878] clocksource: Switched to clocksource timer
[    0.325183] VFS: Disk quotas dquot_6.6.0
[    0.325300] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.325599] FS-Cache: Loaded
[    0.325954] CacheFiles: Loaded
[    0.345277] NET: Registered protocol family 2
[    0.346641] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[    0.346694] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[    0.346746] TCP: Hash tables configured (established 2048 bind 2048)
[    0.346837] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.346863] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.347171] NET: Registered protocol family 1
[    0.347922] RPC: Registered named UNIX socket transport module.
[    0.347933] RPC: Registered udp transport module.
[    0.347938] RPC: Registered tcp transport module.
[    0.347943] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.349262] hw perfevents: enabled with armv6_1176 PMU driver, 3 counters available
[    0.351663] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[    0.371591] FS-Cache: Netfs 'nfs' registered for caching
[    0.373328] NFS: Registering the id_resolver key type
[    0.373375] Key type id_resolver registered
[    0.373381] Key type id_legacy registered
[    0.377830] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.378195] io scheduler noop registered
[    0.378207] io scheduler deadline registered (default)
[    0.378668] io scheduler cfq registered
[    0.384570] BCM2708FB: allocated DMA memory 4f500000
[    0.384629] BCM2708FB: allocated DMA channel 0 @ d080d000
[    0.388700] Console: switching to colour frame buffer device 40x30
[    0.393475] bcm2835-rng 20104000.rng: hwrng registered
[    0.393632] vc-cma: Videocore CMA driver
[    0.393642] vc-cma: vc_cma_base      = 0x00000000
[    0.393649] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    0.393654] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    0.394049] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[    0.419115] brd: module loaded
[    0.431287] loop: module loaded
[    0.431308] Loading iSCSI transport class v2.0-870.
[    0.432197] usbcore: registered new interface driver smsc95xx
[    0.432225] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    0.660530] Core Release: 2.80a
[    0.660546] Setting default values for core params
[    0.660584] Finished setting default values for core params
[    0.860924] Using Buffer DMA mode
[    0.860937] Periodic Transfer Interrupt Enhancement - disabled
[    0.860942] Multiprocessor Interrupt Enhancement - disabled
[    0.860953] OTG VER PARAM: 0, OTG VER FLAG: 0
[    0.861039] Dedicated Tx FIFOs mode
[    0.861659] WARN::dwc_otg_hcd_init:1032: FIQ DMA bounce buffers: virt = 0xcf514000 dma = 0x4f514000 len=9024
[    0.861686] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[    0.861696] dwc_otg: Microframe scheduler enabled
[    0.861785] WARN::hcd_init_fiq:459: FIQ on core 0 at 0xc04512ec
[    0.861797] WARN::hcd_init_fiq:460: FIQ ASM at 0xc04515c8 length 36
[    0.861822] WARN::hcd_init_fiq:486: MPHI regs_base at 0xd0878000
[    0.861892] dwc_otg 20980000.usb: DWC OTG Controller
[    0.861957] dwc_otg 20980000.usb: new USB bus registered, assigned bus number 1
[    0.862065] dwc_otg 20980000.usb: irq 56, io mem 0x00000000
[    0.862117] Init: Port Power? op_state=1
[    0.862122] Init: Power Port (0)
[    0.862476] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.862492] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.862502] usb usb1: Product: DWC OTG Controller
[    0.862511] usb usb1: Manufacturer: Linux 4.9.35+ dwc_otg_hcd
[    0.862520] usb usb1: SerialNumber: 20980000.usb
[    0.863669] hub 1-0:1.0: USB hub found
[    0.863753] hub 1-0:1.0: 1 port detected
[    0.864658] dwc_otg: FIQ enabled
[    0.864667] dwc_otg: NAK holdoff enabled
[    0.864672] dwc_otg: FIQ split-transaction FSM enabled
[    0.864692] Module dwc_common_port init
[    0.865193] usbcore: registered new interface driver usb-storage
[    0.865646] mousedev: PS/2 mouse device common for all mice
[    0.867268] bcm2835-wdt 20100000.watchdog: Broadcom BCM2835 watchdog timer
[    0.867759] bcm2835-cpufreq: min=700000 max=1000000
[    0.868360] sdhci: Secure Digital Host Controller Interface driver
[    0.868367] sdhci: Copyright(c) Pierre Ossman
[    0.868850] sdhost-bcm2835 20202000.sdhost: could not get clk, deferring probe
[    0.871385] mmc-bcm2835 20300000.mmc: could not get clk, deferring probe
[    0.871545] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.872070] ledtrig-cpu: registered to indicate activity on CPUs
[    0.872214] hidraw: raw HID events driver (C) Jiri Kosina
[    0.872479] usbcore: registered new interface driver usbhid
[    0.872485] usbhid: USB HID core driver
[    0.873690] vchiq: vchiq_init_state: slot_zero = 0xcf580000, is_master = 0
[    0.876053] Initializing XFRM netlink socket
[    0.876109] NET: Registered protocol family 17
[    0.876286] Key type dns_resolver registered
[    0.878619] registered taskstats version 1
[    0.879280] vc-sm: Videocore shared memory driver
[    0.879305] [vc_sm_connected_init]: start
[    0.885274] [vc_sm_connected_init]: end - returning 0
[    0.893955] 20201000.serial: ttyAMA0 at MMIO 0x20201000 (irq = 81, base_baud = 0) is a PL011 rev2
[    0.896333] sdhost: log_buf @ cf513000 (4f513000)
[    0.968959] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    0.971497] mmc-bcm2835 20300000.mmc: mmc_debug:0 mmc_debug2:0
[    0.971512] mmc-bcm2835 20300000.mmc: DMA channel allocated
[    1.002062] random: fast init done
[    1.049102] of_cfs_init
[    1.049273] of_cfs_init: OK
[    1.052556] Waiting for root device PARTUUID=3d24ca30-02...
[    1.065319] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    1.066960] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.068599] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    1.071854] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    1.109654] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.112578] mmc0: new high speed SDXC card at address aaaa
[    1.113803] mmcblk0: mmc0:aaaa SL64G 59.5 GiB
[    1.117170]  mmcblk0: p1 p2
[    1.178322] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    1.178337] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    1.180182] mmc1: new high speed SDIO card at address 0001
[    1.488774] EXT4-fs (mmcblk0p2): recovery complete
[    1.491701] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.491795] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.493884] devtmpfs: mounted
[    1.495125] Freeing unused kernel memory: 400K (c0840000 - c08a4000)
[    1.495133] This architecture does not have kernel memory protection.
[    1.785271] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    1.785879] systemd[1]: Detected architecture 'arm'.
[    1.923178] NET: Registered protocol family 10
[    1.925107] systemd[1]: Inserted module 'ipv6'
[    1.929942] systemd[1]: Set hostname to <retropie>.
[    1.930336] systemd[1]: Initializing machine ID from random generator.
[    1.930857] systemd[1]: Installed transient /etc/machine-id file.
[    2.618026] systemd[1]: Cannot add dependency job for unit regenerate_ssh_host_keys.service, ignoring: Unit regenerate_ssh_host_keys.service failed to load: No such file or directory.
[    2.624746] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    2.625596] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    2.625818] systemd[1]: Starting Remote File Systems (Pre).
[    3.062600] fuse init (API version 7.26)
[    4.966239] systemd-udevd[130]: starting version 215
[    7.524786] gpiomem-bcm2835 20200000.gpiomem: Initialised: Registers at 0x20200000
[    7.633015] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    8.869814] usbcore: registered new interface driver brcmfmac
[    9.053786] brcmfmac: Firmware version = wl0: Aug  7 2017 00:46:29 version 7.45.41.46 (r666254 CY) FWID 01-f8a78378
[    9.739566] systemd-journald[126]: Received request to flush runtime journal from PID 1
[   10.530288] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
[   10.551453] fb_ili9340: module is from the staging directory, the quality is unknown, you have been warned.
[   10.552543] fbtft_of_value: buswidth = 8
[   10.552553] fbtft_of_value: debug = 0
[   10.552559] fbtft_of_value: rotate = 270
[   10.552565] fbtft_of_value: fps = 40
[   11.268058] graphics fb1: fb_ili9340 frame buffer, 320x240, 150 KiB video memory, 4 KiB DMA buffer memory, fps=50, spi0.0 at 60 MHz
[   11.963942] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[   11.963975] brcmfmac: power management disabled
[   12.671743] uart-pl011 20201000.serial: no DMA platform data
[   13.701136] Adding 102396k swap on /var/swap.  Priority:-1 extents:2 across:266236k SSFS
[   16.363105] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   17.127872] Bluetooth: Core ver 2.22
[   17.127994] NET: Registered protocol family 31
[   17.128000] Bluetooth: HCI device and connection manager initialized
[   17.131318] Bluetooth: HCI socket layer initialized
[   17.131340] Bluetooth: L2CAP socket layer initialized
[   17.131392] Bluetooth: SCO socket layer initialized
[   17.144053] Bluetooth: HCI UART driver ver 2.3
[   17.144067] Bluetooth: HCI UART protocol H4 registered
[   17.144072] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   17.144254] Bluetooth: HCI UART protocol Broadcom registered
[   17.462883] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   17.462894] Bluetooth: BNEP filters: protocol multicast
[   17.462923] Bluetooth: BNEP socket layer initialized
[   23.971420] input: retrogame as /devices/virtual/input/input0
[   53.218983] random: crng init done
Update: From what I have been reading on these forums, there seems to be a batch of bad TFTs floating around in these Pigrrl Zero kits which lead to the white screen. I've resoldered the joints and removed all the wiring except for the Powerboost with no luck.
sguttmann
by sguttmann on Wed Feb 07, 2018 2:34 pm
Since the last post, I have removed all the solder and resoldered all the joints. Also I did the PiTFT install seen here: https://learn.adafruit.com/adafruit-2-2 ... i?view=all. No luck. Any suggestions from Tech Support?
sguttmann
by sguttmann on Mon Feb 19, 2018 9:12 pm
OK, here's the deal. Since I have not heard anything from customer support, I went ahead and resoldered the joints once again with no luck. I decided to start over and re-purchased the PiTFT and Pi Zero W from Adafruit. Now, the TFT works as expected but the USB port and wireless are not functioning. I know this because with the same setup, the previous Pi Zero build recognized the keyboard and the wireless network with no problem. Therefore, the original TFT was defective and now the recent Pi Zero is a no go. This will be the last time I will purchase anything from Adafuit since they do not seem to acknowledge an obvious problem.
sguttmann
by sigilvii on Fri Mar 09, 2018 7:10 pm
I'm having the exact same problem (my post). I saw that you eventually heard back from Customer Support. Were you successful in getting a replacement?
I'm going to send them an email and I hope to hear back soon.
I hope you were eventually able to get your PiGRRL Zero up and running!
sigilvii
by sguttmann on Fri Mar 09, 2018 9:13 pm
Yes I eventually received the replacement but sadly, I have not had success with this project. I soldered the replacement PiTFT to a presoldered Pi Zero (which I tested the ports beforehand) and managed to boot into Retropie once. The USB worked fine but the WiFi was not working (there are multiple threads of how the PiTFT kills the wifi on the Pi Zero). After a reboot, I got the white screen and was never able to replicate the PiTFT functioning after the first try. I even used different Retropie images with no luck. Between this and the last post, I purchased another PiTFT and pre-soldered Pi Zero from Adafruit and managed to have the PiTFT display to function, but the USB and wifi was dead so it was basically useless. It was partly my fault for not testing the USB and wifi prior to installation of the PiTFT. So I now have three non-functioning Pi Zero/PiTFTs.
sguttmann
by sigilvii on Sat Mar 10, 2018 1:16 am
I'm sorry to hear that, that really sucks. It makes me very apprehensive to keep trying with this project.
sigilvii
