code for serial LCD
code for serial LCD
by emesine on Sun Feb 04, 2018 11:14 am
I am using this item:
USB + Serial Backpack Kit with 16x2 RGB backlight positive LCD - Black on RGB
I am communicating with the device using TTL, from a pin on my metro mini, not through the serial port.
I would like to set the screen to red, at about 50% brightness. Can someone help me with a code that will do this? Thanks!
emesine
Re: code for serial LCD
by emesine on Sat Feb 10, 2018 1:38 pm
This works:
So the first line after the commands calling it to attention, tells the Red led to be on at 254 Full brightness.
The next line says green be off or as near to off as i can get. 1
Next line says blue off or 1
I simply called the value in 0-255 format and not hex. You need to call all 3 led’s or it won’t work.
So to control the backlight you need this code running in the loop with a delay
lcd.write(0xFE);
lcd.write(0xD0); // First 2 lines call the attention of the chip and tells it we are going to change the colour
lcd.write(254); // RED Change the next 3 lines to a value for the colour
lcd.write(1); //Green
lcd.write(1); //Blue
delay(500); // give it some time to adjust the backlight!
For Green
lcd.write(0xFE);
lcd.write(0xD0); // First 2 lines call the attention of the chip and tells it we are going to change the colour lcd.write(1); // RED Change the next 3 lines to a value for the colour
lcd.write(254); //Green
For Blue
lcd.write(0xFE);
lcd.write(254); //Blue
emesine
