PIOLED weird text
PIOLED weird text
by xXFuqqYoCouch on Thu Feb 08, 2018 1:27 am
Hello.
recently i hooked up a PIOLED and set it up for PI-Hole. but when I run the PI_hole stats it displays the stats along with "RBSEBERRY PI 4" kind of mushed in between some of the text.
Here is a picture.
xXFuqqYoCouch
Re: PIOLED weird text
by adafruit_support_carter on Fri Feb 09, 2018 2:42 pm
Are you running the code as is from the guide?
https://learn.adafruit.com/pi-hole-ad-b ... all-pioled
by xXFuqqYoCouch on Fri Feb 09, 2018 5:49 pm
adafruit_support_carter wrote:Are you running the code as is from the guide?
Yes.
xXFuqqYoCouch
by adafruit_support_carter on Mon Feb 12, 2018 12:21 pm
Is "RBSEBERRY PI 4" the hostname for the Pi you are running this on? If so, I think it's just wrapping the text because it's too long to fit on one line.
