RGB Matrix and RTC DS3231 problem
mpt
Post by mpt »
On Arduino Nano I want display time on 32x32 led panel from RTC DS3231 module. When i run example from AdaFruit RGBmatrixPanel testshapes_32x32 everything is ok
but when i add RTC library
#include <Wire.h>
#include <DS3231.h>
program don't work, led panel display only random pixels. When i comment RTC code, program displays on panel correctly. I notice also that when i uncomment DS3231 libraries (include) only, program not work properly again. Where is the problem?
#include <Wire.h>
#include <DS3231.h>
#include <Adafruit_GFX.h>   // Core graphics library
#include <RGBmatrixPanel.h> // Hardware-specific library
#define CLK 8  // MUST be on PORTB! (Use pin 11 on Mega)
#define OE  9
#define LAT 10
#define A   A0
#define B   A1
#define C   A2
#define D   A3
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, false);
//DS3231 clock;
//RTCDateTime dt;
void setup()
  matrix.begin();
  //Serial.begin(9600);
  //Inicjalizacja DS3231
  //Serial.println("Initialize DS3231");;
  //clock.begin();
  // Ustawiamy date i czas z kompilacji szkicu
  //clock.setDateTime(__DATE__, __TIME__);
  // Lub recznie (YYYY, MM, DD, HH, II, SS
  // clock.setDateTime(2014, 4, 13, 19, 21, 00);
void loop()
  // Odczytujemy czas i formatujemy za pomoca funkcji dateFormat
  //dt = clock.getDateTime();
  //Serial.println(clock.dateFormat("H:i:s", dt));
  matrix.fillScreen(matrix.Color333(0, 0, 0));
  delay(1000);
  matrix.setCursor(1, 0);    // start at top left, with one pixel of spacing
  matrix.setTextSize(1);     // size 1 == 8 pixels high
  matrix.setTextWrap(false); // Don't wrap at end of line - will do ourselves
  matrix.setTextColor(matrix.Color333(7,7,7));
  matrix.println("Test");
  delay(1000);
AdriaanHeijnen
Re: RGB Matrix and RTC DS3231 problem
Post by AdriaanHeijnen »
i have the same problem when using the following code.
// Date and time functions using a DS3231 RTC connected via I2C and Wire lib
//#include <Wire.h>
//#include "RTClib.h"
including one or both gives random results.
Also when using serial for testing the RGB sometimes stops the working. can this be caused by multiple interupts?
