Daisy chain Neopixel Rings and Strips
by jacobshepherd on Thu Feb 08, 2018 11:55 am
Can I daisy chain Neopixel Rings (24 LED) with Neopixel Strips (144 LED)?
jacobshepherd
Re: Daisy chain Neopixel Rings and Strips
by adafruit_support_bill on Thu Feb 08, 2018 12:02 pm
Yes. Just don't mix the RGB with the RGBW variety.
Also, the 144 strips are pretty power hungry. You will want to feed 5v & GND direct to both ends of the strip. Don't try to daisy-chain the power for the strip through the ring.
by jacobshepherd on Sun Feb 11, 2018 2:37 pm
Awesome, thank you. If I have a 5v 5amp 25 watt power supply, is that enough for arduino micro, raspberry pi 3, 9 neopixel rings and two of the 144 light strips?
jacobshepherd
by adafruit_support_bill on Sun Feb 11, 2018 7:40 pm
That depends on what you have attached to the Pi and how hard you drive the strips.
Displays and other peripherals can add significantly to the Pi's power requirements.
9 x 24 pixel rings and 2 x 144 pixel strips is 504 pixels. In theory, with all pixels at full intensity white, these could draw 30 amps or more (40 amps for the RGBW variety). In practice, most applications do not run them that hard.
This guide has some good advice on how to use power effectively with Neopixels: https://learn.adafruit.com/sipping-powe ... l#overview
