Potentially Defective 16 x 32 RGB LED Matrix (PID 420)
by wrussotto on Sat Feb 10, 2018 12:55 am
I recently purchased a Medium 16 x 32 RGB LED matrix (Product ID 420, see here: https://www.adafruit.com/product/420). Out of the box, I noticed something that looks like it could be a defect in the manufacturing of the PCB. I attached an image so you can see more clearly:
The IC "U2" is doused in flux and there appears to be solder bridging together pins 5-6 and 7-8. I looked up the part number GM245TS and can't find any documentation. Looking at the pictures on the product's page on Adafruit, this seems to be a newer version of the board, so I don't really have a working reference (or a schematic). I'm nervous about connecting this board to power since there's really no way to know if this is actually a defect or intentional.
Could you check to see if any other units have this similar solder bridging on U2? Or is this a defective unit? I could also try reworking the solder to undo the bridges, but I don't want to risk damaging the board.
Best Regards,
Will Russotto
wrussotto
Re: Potentially Defective 16 x 32 RGB LED Matrix (PID 420)
by adafruit2 on Wed Mar 07, 2018 3:51 pm
its worth trying it out, its very very unlikely you will damage any attached hardware, and these panels often get reworked so its not *too* shocking :)
adafruit2
Site Admin
cron
