Where can I find a power connector
by bjazmoore on Tue Feb 13, 2018 4:46 pm
I have purchased several of the 64x32 RGB LED Matrix - 5mm pitch - PRODUCT ID: 2277. I also have the driver board (HAT) for these Matrix displays for the RPi. I love them by the way! I am having an issue daisy chaining two of the 64x32 matrix displays together as the power ports are too far apart for the power cables that come with the boards to reach both matrix displays. I can cut the wire and solder in an extension, but I would rather get some of the little white plugs (like those supplied) that are not yet terminated and build my own cables. Can someone point me to where I can buy some of those four pin power connectors? Or even what they are called.
bjazmoore
Re: Where can I find a power connector
by danhalbert on Sat Feb 17, 2018 12:23 pm
Someone else had a similar question about a year ago and may have found matching connectors. See here: viewtopic.php?f=19&t=32905
danhalbert
by bjazmoore2 on Sat Feb 17, 2018 4:20 pm
Perfect. Thank you.
bjazmoore2
