Adafruit PiTFT Plus 320x240 2.8" TFT + Capacitive Touchscree
by asku on Sat Mar 03, 2018 7:47 pm
I purchased the Adafruit PiTFT Plus 320x240 2.8" TFT + Capacitive Touchscreen this past November (if that helps with what version it is as the manual says they have been many changes made over time) and I followed these steps using the default options after setting up my pi the way I wanted:
1. sudo raspi-config --> Advanced options --> (expand filesystem) --> sudo reboot
2. curl -SLs https://apt.adafruit.com/add-pin | sudo bash
3. sudo apt-get install raspberrypi-bootloader adafruit-pitft-helper raspberrypi-kernel
4. sudo adafruit-pitft-helper -t 28r
I purchased a stylus but still nothing I do on the screen is showing a response. Any ideas about what I need to do to fix this?
Screen Shot 2018-03-03 at 6.41.44 PM.png (380.27 KiB) Viewed 287 times
asku
Re: Adafruit PiTFT Plus 320x240 2.8" TFT + Capacitive Touchs
by adafruit_support_carter on Mon Mar 05, 2018 1:00 pm
Looks like you may have installed the resistive touch version. Change the 'r' to a 'c' at the very end.
https://learn.adafruit.com/adafruit-2-8 ... -the-pitft
by asku on Mon Mar 05, 2018 2:04 pm
Thanks! That was a quick fix. Now I have an issue where the mouse will only move within a small area near the top left corner of the screen. I can select the menu after start up but nothing else is accessible within the small area. Any thoughts on a missed/incorrect step that could cause this behavior?
asku
by Eskiimov on Tue Mar 06, 2018 6:39 am
What version OS are you running?
I just tried a fresh image Raspbian Stretch, and update+upgrade, then tried to run the install guide, but i cant for some reason, and i don't know why.
It already fails at
I get an error
W: GPG error: http://apt.adafruit.com/raspbian wheezy InRelease: The following signatures were invalid: 58A1FE78D61C7C13E28B92A7C24E6D5378661FA5
W: The repository 'http://apt.adafruit.com/raspbian wheezy InRelease' is not signed.
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Is because i must use Jessie?
Eskiimov
by adafruit_support_carter on Tue Mar 06, 2018 11:55 am
@Eskiimov Please start a new thread for your issue.
by adafruit_support_carter on Tue Mar 06, 2018 12:04 pm
Let's see if the screen is responding to touches across the entire area. Try installing these tools:
https://learn.adafruit.com/adafruit-2-8 ... nt-testing
and then with the touchscreen utility running, try touching various locations across the entire screen to make sure it is reporting.
by asku on Wed Mar 07, 2018 12:04 am
All of that works very well, so I’m not sure why I can’t get the same response on the RPi desktop. Clicking anywhere on the screen, including an opposite corner, clicks the mouse which is locked in a small area near the top left corner.
asku
by adafruit_support_carter on Thu Mar 08, 2018 3:23 pm
Cool. At least we now know the hardware works. So now it's most likely just something in the software somewhere. What OS and version are you starting out with?
by asku on Thu Mar 08, 2018 4:37 pm
cat /etc/debian_version shows 8.0
cat /etc/os-release gives
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
and
uname -a gives
Linux mypi 4.4.27-v7+ #2 SMP Wed Oct 26 19:09:12 UTC 2016 armv7l GNU/Linux
asku
by adafruit_support_carter on Wed Mar 14, 2018 12:12 pm
Try one of the ready to go images from here:
https://learn.adafruit.com/adafruit-2-8 ... o-go-image
