White Screen on 2.2 PiTFT for PiGRRL Zero
Re: White Screen on 2.2 PiTFT for PiGRRL Zero
by Hellasius on Sun Apr 08, 2018 1:19 pm
oxyink wrote:464/5000
Hello everyone, sorry I was away. So for my part, I just write my image retropie with etcher, then I followed the tutorial Adafruit.
eventually I had the white screen every time.
doing some modifications on all sides is what made my project work:
Write the Retropie image again.
Follow the complete tutorial but at the step:
run sudo nano /boot/config.txt
Do not copy the Adafruit lines.
Add this to the following:
#overclocking extreme
arm_freq=1100
core_freq=550
sdram_freq=600
over_voltage=8
over_voltage_sdram=6
force_turbo=1
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
#forcing HDMI output at TFT screen resolution to be able to make the FB copy
#resolution configuration
hdmi_force_hotplug=1
hdmi_cvt=320 240 60 1 0 0 0
hdmi_group=2
hdmi_mode=87
# working config for speed
# 900 Mhz -> 48000000
# 1Ghz -> 35000000
#modification of the speed
dtoverlay=pitft22,rotate=270,speed=60000000,fps=40
Also make sure your welds are ok.
For me everything worked perfectly after that, I hope I could help you.
I do not thank Adafruit who do nothing and leave their customers without information.
Hello oxyink,
I tried to add the line at the end of the config.txt. And it doent work = White screen.
Is it possile to share your IMG file that I can try exactly your image? I think we have the same PiTFT and same Pi, If it's working for you it should be working for me too...
Hellasius
by sajingeo on Sun Apr 08, 2018 10:50 pm
I have the same issues with a TFT screen I bought from microcenter. Really annoyed by the fact I will have to de-solder the entire TFT to try out a replacement.
sajingeo
by sajingeo on Sun Apr 08, 2018 10:55 pm
Why is micro-center still selling if Adafruit has put a hold on this?? I just spent 44$ for this kit.
sajingeo
by Hellasius on Mon Apr 09, 2018 8:59 am
I finaly succeed making my piTFT working by doing the modification on the config.txt as desctibe above.
I replace all the config.txt file by:
arm_freq=1100
core_freq=550
sdram_freq=600
over_voltage=8
force_turbo=1
dtparam=spi=on
dtparam=i2c1=on
dtparam=i2c_arm=on
hdmi_group=2
hdmi_mode=87
# 1Ghz -> 35000000
Screen is not working perfectly, sometimes when I power the pigrrl zero, I have white screen. I switch off everything, wait 1 or 2 minutes and power again and it's working.
Maybe I have deleted a line on the config.txt that I shouldn't... (If you have advice about it...).
Finally the screen is working, now I have some trouble running some Roms on GBA, but it's another story.
Hellasius
by sajingeo on Mon Apr 09, 2018 9:51 am
Just tried that out. Does not seem to work. I Do see the screen blink or sometimes go from white to black.
sajingeo
by adafruit2 on Sat Apr 14, 2018 10:49 pm
a friendly person's RMA has helped us figure out what happened. to keep it easier for us to track this issue, please see:
viewtopic.php?f=50&t=132799&p=665628
thanks!
adafruit2
Site Admin
by sajingeo on Sun Apr 22, 2018 10:44 am
its works!! changing the transistor worked :)
sajingeo
by adafruit2 on Sun Apr 22, 2018 12:17 pm
awesome!! nice work :)
adafruit2
Site Admin
