Adafruit TFT 1.44" LCD with line in the top half of display
by ts4s on Fri Mar 09, 2018 5:45 pm
Just received 2 of these 1.44 tft LCD and have them hooked up for animated eyes. Noticed one of them has lines through the top of the display. I've swapped ports and wire connection to the snake eyes bonnet. Is there anything else I can check for or does it need to be RMA? Attached is a photo of the issue. Thank You
ts4s
Re: Adafruit TFT 1.44" LCD with line in the top half of disp
by adafruit_support_mike on Tue Mar 13, 2018 6:40 pm
To confirm, have you tested both displays, swapped the connections, found that the display shown above had the same output in both cases, and the other display worked normally in both cases?
by ts4s on Wed Mar 14, 2018 2:00 pm
yes, the other display works normally like it should.
ts4s
by ts4s on Thu Mar 15, 2018 2:30 pm
Here’s photo’s from video of the issue(sorry can’t upload mov files). It’s showing the issue follows the lcd.
ts4s
2nd photo
ts4s
