Neopixel ring one LED stays on
by LadyPrelude on Fri Mar 09, 2018 8:02 pm
Hi there, I'm using a 24 Neopixel ring and one of the pixels won't go out. I've checked my code and can't see a problem there, I've also tried sample codes and get the same result. The LED is also a slightly different colour to the others, they are blue and the one LED has a green tint to it. Any ideas what might cause this please? The video link below is one I've uploaded to show what I mean, the pixel at the bottom stays on, it should go out with the others. Many thanks
https://youtu.be/ccWEBcMZKhU
LadyPrelude
Re: Neopixel ring one LED stays on
by adafruit_support_bill on Fri Mar 09, 2018 8:15 pm
Please post the code you are using to drive the ring.
by LadyPrelude on Fri Mar 09, 2018 8:34 pm
this is the code. Thanks
#define PIN 1
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
//   NEO_KHZ800  800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
//   NEO_KHZ400  400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
//   NEO_GRB     Pixels are wired for GRB bitstream (most NeoPixel products)
//   NEO_RGB     Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(29, PIN, NEO_GRB + NEO_KHZ800);
int ringRightSide[] = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12};
int ringLeftSide[] = {0, 23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12};
int singlePixels[] = {24, 25, 26, 27, 28};
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
int pos = 0;
int pos2 = 0;
    // Draw 5 pixels centered on pos.  setPixelColor() will clip any
  // pixels off the ends of the strip, we don't need to watch for that.
  strip.setPixelColor(ringRightSide[abs((pos - 2)%13)], strip.Color(0, 0, 80)); // Dark blue
  strip.setPixelColor(ringRightSide[abs((pos - 1)%13)], strip.Color(0, 0, 150)); // Medium blue
  strip.setPixelColor(ringRightSide[abs((pos    )%13)], strip.Color(15, 15, 200)); // Center pixel is brightest
  strip.setPixelColor(ringRightSide[abs((pos + 1)%13)], strip.Color(0, 0, 150)); // Medium blue
  strip.setPixelColor(ringRightSide[abs((pos + 2)%13)], strip.Color(0, 0, 80)); // Dark blue
  strip.setPixelColor(ringLeftSide[abs((pos - 2)%13)], strip.Color(0, 0, 80)); // Dark blue
  strip.setPixelColor(ringLeftSide[abs((pos - 1)%13)], strip.Color(0, 0, 150)); // Medium blue
  strip.setPixelColor(ringLeftSide[abs((pos    )%13)], strip.Color(15, 15, 200)); // Center pixel is brightest
  strip.setPixelColor(ringLeftSide[abs((pos + 1)%13)], strip.Color(0, 0, 150)); // Medium blue
  strip.setPixelColor(ringLeftSide[abs((pos + 2)%13)], strip.Color(0, 0, 80)); // Dark blue
  strip.setPixelColor(singlePixels[abs(pos2 - 1)], strip.Color(0, 0, 80)); // Dark blue
  strip.setPixelColor(singlePixels[abs(pos2    )], strip.Color(15, 15, 200)); // Center pixel is brightest
  strip.setPixelColor(singlePixels[abs(pos2 + 1)], strip.Color(0, 0, 80)); // Dark blue
    strip.show();
  delay(100);
    // Rather than being sneaky and erasing just the tail pixel,
  // it's easier to erase it all and draw a new one next time.
  for(int j=-2; j<= 2; j++) {
    strip.setPixelColor(ringRightSide[(pos+j)%13], 0);
    strip.setPixelColor(ringLeftSide[(pos+j)%13], 0);
    strip.setPixelColor(singlePixels[(pos2+j)%5], 0);
  pos += 1;
  if(pos < 0) {
    pos = 1;
  } else if(pos >= 13) {
    pos = 0;
  pos2 += 1;
  if(pos2 < 0) {
    pos2 = 1;
  } else if(pos2 >= 6) {
    pos2 = 0;
Last edited by adafruit_support_bill on Sat Mar 10, 2018 6:53 am, edited 1 time in total.
Reason: please use [code] tags when posting code to the forums.
LadyPrelude
by adafruit_support_bill on Sat Mar 10, 2018 7:48 am
You have the ring defined as 29 pixels. But I think that the math still works out. Just to be sure, let's try a simple test.
Run this code and check to see if the pixel is still stuck:
#define PIN 1
  strip.begin();
int pos = 0;
int pos2 = 0;
void loop()
    for int i = 0; i < strip.numPixels(), i++)
        strip.setPixelColor(i, strip.Color(15, 15, 200)); // Center pixel is brightest
        strip.show();
        delay(100);
        strip.setPixelColor(i, 0); // off
        strip.show();
by LadyPrelude on Sat Mar 10, 2018 9:20 am
sorry code doesn't run?
I get the following errors
code error2.jpg (131.27 KiB) Viewed 227 times
The reason for 29 is because I want to add 10 flora pixels as well, 5 each side. I havent tested to see if this works yet.
Many thanks
LadyPrelude
by adafruit_support_bill on Sat Mar 10, 2018 9:32 am
Sorry, That's what happens when I code before I have my coffee.
Try this:
#define PIN 1
  strip.begin();
int pos = 0;
int pos2 = 0;
void loop()
    for (int i = 0; i < strip.numPixels(); i++)
        strip.show();
        delay(100);
        strip.show();
by LadyPrelude on Sat Mar 10, 2018 10:57 am
LOL! thank you.
Got the follow error code when uploading.
code error.jpg (184.22 KiB) Viewed 213 times
The ring did light up, and the one pixel that won't go out is a different colour? I'll post a picture. Do you think its faulty?
LadyPrelude
by LadyPrelude on Sat Mar 10, 2018 11:01 am
Pixel at the top
LadyPrelude
by adafruit_support_bill on Sat Mar 10, 2018 11:04 am
Ok. Please contact support@adafruit.com with a link to this thread and we can send out a replacement.
by LadyPrelude on Sat Mar 10, 2018 1:19 pm
Will do. I've just placed another order, so hopefully they can be sent at the same time.
Thank you for your help :)
LadyPrelude
by LadyPrelude on Sun Mar 11, 2018 2:50 pm
Hi, thanks for sorting this out for me. I wonder if I could ask you another question please. The flora pixels are not working, and looking at the code I am using it does say V1 not V2 and yep I am using V2. Can I ask what do I need to do to this code to make it work with flora v2 please? Many thanks.
LadyPrelude
by adafruit_support_bill on Sun Mar 11, 2018 3:04 pm
In your code where you declare the pixels, make sure you specify NEO_KHZ800.
NEO_KHZ400 is for V1 pixels
NEO_KHZ800 is for V2.
by LadyPrelude on Sun Mar 11, 2018 4:50 pm
Fantastic, thanks so much :)
LadyPrelude
