Featherwing 2.4" TFT
by abear7 on Sat Mar 10, 2018 3:41 pm
Hello, I have the demo running OK and I'm trying a simple display now. I want just fixed text and a timer to update smoothly every second.
How do you get it to just update a timer value on the screen without having to rewrite the whole screen to avoid flicker from using the fillScreen(...BLACK); function?
abear7
Re: Featherwing 2.4" TFT
by coburn64 on Sat Mar 10, 2018 7:54 pm
I believe the draw text functions support a background color parameter. I do remember that you could do something like drawText("blah", WHITE, BLACK, 0,0) (maybe it's setBackgroundColor and setColor ?) or something to that extent. I think then internally the text drawing function will draw a filled box over the area you want the text drawn before it draws the font.
coburn64
by abear7 on Mon Mar 12, 2018 9:14 pm
I saw and tried some of these functions but the IDE says function not found for some reason.
void setCursor(uint16_t x0, uint16_t y0);
void setTextColor(uint16_t color);
void setTextColor(uint16_t color, uint16_t backgroundcolor); void setTextSize(uint8_t size);
void setTextWrap(boolean w);
The only way I've been able to work around this is remember every character I print and go print that again in Black before printing at that location again. Am I the only one who has this problem?
I'm using code like this below which the demo had several examples of:
tft.setTextSize(2);
tft.print("new message");
These are the header files which the demo already included.
Help would be much appreciated.
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
abear7
by abear7 on Fri Mar 23, 2018 9:29 pm
Hello, I'm still having this issue. None of the demos demonstrate rewriting text to a same location on the screen without blanking out the whole screen first so I'm wondering if this is just how it works. Any assistance would be appreciated.
abear7
by BryonMiller on Sat Mar 24, 2018 10:02 am
Rather than a fillscreen I write a black rectangle on top of the old text to be replaced
Something like
tft.fillRect(X,Y,27*6*3,8*3,BLACK);
where
X      is the x coordinate of the text I was using
Y      is the y coordinate of the text I was using
27     is the maximum number of old characters I was using
6      is the library x width of a single character
3      is text size I was using
8      is the library y height of a single character
BryonMiller
by abear7 on Sat Mar 24, 2018 11:30 am
Hello, Yes I thought of doing that also. I was hoping there was something simpler. If I redo the layout and keep static areas unmodified and use this approach over areas that change this might make things a bit easier.
abear7
by abear7 on Fri Mar 30, 2018 4:17 pm
This approaching is working fine. I just wished I knew this before hand, which would have saved me frustration and time.
abear7
