Plugin Power Supply for Electroluminescent (EL) Wire
by chilump on Mon Mar 12, 2018 12:36 pm
I would like to purchase High Brightness Pink Electroluminescent (EL) Wire - 2.5 meters - High brightness, long life
PID: 404
Which plugin power supply do I use?
chilump
Re: Plugin Power Supply for Electroluminescent (EL) Wire
by adafruit_support_bill on Mon Mar 12, 2018 12:43 pm
You will need an inverter like this one: https://www.adafruit.com/product/448
That can be powered from batteries, or a 12v plug-in power supply like this one: https://www.adafruit.com/product/798
by chilump on Mon Mar 12, 2018 1:36 pm
Great! Thanks
chilump
by chilump on Mon Mar 12, 2018 1:42 pm
If I go with the plugin is there any way to add additional strands and run off the same inverter and 12v plug?
Or is the only option to extend?
chilump
by adafruit_support_bill on Mon Mar 12, 2018 1:50 pm
That inverter will handle up to 6 meters total of the high brightness wire. You can probably run 2 or 3 of the inverters from the plug-in supply.
by Jefffydee on Tue Mar 13, 2018 7:38 am
I just purchased the sound activated inverter. It is my understanding that inverter can be plugged into a DC power supply instead of a battery pack. My question is how many amps can the inverter take? And approximately how much el wire/ el tape can be driven off of it? Sorry for bombarding this post I just had a very related question and figured knowledge is power, yes?
Jefffydee
by adafruit_support_bill on Tue Mar 13, 2018 7:56 am
Current draw is determined by the load, not the supply. It will draw only what it needs. Typically less than 100mA.
These will drive 2-3 meters of high brightness wire.
by Jefffydee on Tue Mar 13, 2018 8:01 am
Okay, so lets say I plug in a 3A 12V DC power supply, it wont fry the inverter or hurt anything. The power supply can HANDLE 3A but may only use say 500ma
Jefffydee
by adafruit_support_bill on Tue Mar 13, 2018 8:16 am
That is correct. The inverter will only draw as much power as it needs from your supply.
