LED Matrix Mounts
- HowardAbraham
LED Matrix Mounts
Does anyone know where to buy mounting kits for these LED Matrix panels?
- Franklin97355
Re: LED Matrix Mounts
Which panel are you asking about?
- HowardAbraham
- Franklin97355
As far as I know, there is no "kit" you would mount them with the six screw inserts on the back.
- HowardAbraham
You may be right. I just figured that if these are intended for commercial use, it would be reasonable to assume there is a standard-ish mounting panel that would be compatible. It's possible that every application in the field is a custom solution.
- Franklin97355
I'm thinking the sign company that is installing these for businesses has a frame for their standard panel sizes probably made in-house.
