PiOLED Not Displaying
by jljozsa on Fri Mar 23, 2018 12:42 pm
Hello - first let me apologize if I am posting in the wrong place; I'm very new to forums.
I purchased a PiOLED on 3/15/2018 (order # 1709982-9456734411) and I cannot get the display to work.
I built a Pi-Hole and I've been following this guide (https://learn.adafruit.com/adafruits-ra ... guring-i2c) to get i2c configured, When I get to the step to enter 'sudo i2cdetect -y 1', it isn't detecting my PiOLED.
I've tried soldering/re-soldering the GPIO header, I've tried a Hammer Header Male Solderless Raspberry Pi Connector, I've tried on 3 different Pi Zeros - all getting the same result. When testing, I was able to get a 3.5 inch PiTFT display to work.
Is there something I'm missing, or is it possible that I received a dud display?
jljozsa
Re: PiOLED Not Displaying
by adafruit_support_carter on Fri Mar 23, 2018 1:03 pm
Sounds like you've got various GPIO header styles - solder, hammer, etc. The PiOLED works on none of them (correct?). How about the PiTFT - did it work on all 3 Pi's? If it did, pick the one you think has the best GPIO headers installed. If not, then let's use the one where it did work.
Post a photo of the Pi Zero you're trying to use showing the GPIO header installation (so I can check either the soldering or how well the hammer header worked). Also post a photo showing how you are trying to use the PiOLED.
by jljozsa on Mon Mar 26, 2018 9:35 am
Will do - apologies; on the road should be back tomorrow, will resume testing!
jljozsa
by jljozsa on Thu Mar 29, 2018 8:46 pm
Ok - here is the pi and the solder job. This is the 4th motherboard I've tried it on; my soldering isn't great but it does the trick for everything else.
jljozsa
by adafruit_support_carter on Tue Apr 03, 2018 11:48 am
Sorry for delayed response. I should've asked for clarification on this:
Can you post the actual output you get from running that command.
by jljozsa on Tue Apr 03, 2018 9:57 pm
jljozsa
by adafruit_support_carter on Tue Apr 03, 2018 10:30 pm
Yep. That's nothing. Let's replace it. Send an email to support@adafruit.com with a link to this thread and they can help get you a new Pi OLED.
I'm still a little concerned about the soldering in the photo you posted. But you say a 3.5 inch PiTFT display worked and you tried various Pi Zero's so it could be the display. Please report back if the replacement works.
by jljozsa on Tue Apr 03, 2018 10:33 pm
Will do - thank you!!
jljozsa
by jljozsa on Sat Apr 07, 2018 1:41 pm
Success!! Plugged the new PiOLED in, booted it back up, ran sudo i2cdetect -y 1 and voila:
Thank you so very much!!!!!!
jljozsa
by adafruit_support_carter on Tue Apr 10, 2018 11:43 am
Cool. Glad that worked. Thanks for letting us know.
by Seth_Proaps on Thu Feb 21, 2019 9:38 pm
I am having the exact same problem, but cant find where to start a forum thread to talk to anyone about it, i have all the same problems as him, i get to the detect part and boom, nothing in the chart please help, or show me where to ask for it.
Seth_Proaps
by jljozsa on Fri Feb 22, 2019 10:32 am
Seth,
Try going to viewforum.php?f=47 and selecting 'post a topic' on the upper left-hand side. It's been a while since I've done it, so that may not work, but worth a shot maybe.
jljozsa
by adafruit_support_carter on Fri Feb 22, 2019 12:54 pm
Yep, look for the button that looks like this:
