RGB Matrix Hat/LED not lighting up
by bigal420lol on Tue Apr 03, 2018 2:45 am
Hi!
So I did the stuff for the Adafruit matrix HAT. I have a 32x32 RGB LED panel I got from you, but when I run the display test, nothing shows up on the panel. I'm not sure if I just did a crappy soldering job (was my first time, so this would be my guess) or if the panel is defective, or what. Also, I'm not quite sure how to tell where the problem lies. It's definitely not in the code; the code compiles and runs fine, it's just that the LED panel doesn't light up. I did notice that it flickered for a second when unplugging it, if that helps.
Alex
bigal420lol
Re: RGB Matrix Hat/LED not lighting up
by adafruit_support_carter on Wed Apr 04, 2018 1:01 pm
Let's start by checking your hardware setup. Can you post a photo showing how you have everything connected.
by bigal420lol on Wed Apr 04, 2018 10:34 pm
Here's a couple photos of the connections
bigal420lol
by adafruit_support_carter on Thu Apr 05, 2018 12:49 pm
Thanks for the photos. That all seems fine. Let's check the software.
What are you running here? One of the demos?
by bigal420lol on Thu Apr 05, 2018 1:06 pm
Yep, I'm running the code found in this tutorial:
https://learn.adafruit.com/raspberry-pi ... y/software
Have followed the tutorial exactly, and am using the latest version of Raspbian Jessie.
I'm using a single 32 x 32 4mm pitch panel, and in the config I'm specifying a
chain_length
of 1,
parallel_count
of 1,
panel_width
panel_height
display_width
and
display_height
of 32.
Only including the single
{ order = 0; rotate =   0; }
panel object in the two-dimensional panels array, and leaving the
crop_origin
option commented out so as to output the entire display to the panel.
When I run the
sudo ./display-test matrix.cfg
or
commands, the processes run without error and I can quit them with CTRL+C.
But nothing shows up on the panel.
bigal420lol
by adafruit_support_carter on Thu Apr 05, 2018 1:21 pm
Hmmm. I'm seeing a difference between the guide and the code in the repo. The repo has this:
https://github.com/adafruit/rpi-fb-matr ... kefile#L13
but in the guide, there are more defines. Also, the guide uses DEFINES while the Makefile uses USER_DEFINES.
Try this. Edit your Makefile and change that USER_DEFINES line to this:
export USER_DEFINES=-DADAFRUIT_RGBMATRIX_HAT -DRGB_SLOWDOWN_GPIO=1
and then try building the library again:
make clean all
by bigal420lol on Thu Apr 05, 2018 10:44 pm
Tried this, and when I built the library again it threw some warnings about how this is an old way of specifying the matrix hat hardware. The matrix lit up, but it's some glitchy weirdness. So for the heck of it, I removed the directory and cloned the repo again, rebuilt everything and ran it, and again, just glitchiness. It seems to make a difference whether I supply the matrix.cfg as an argument to the display-test command or run it without argument, but either way, it's just crazy changing colors and not the display that is output to the LED array. Here's a picture:
bigal420lol
by bigal420lol on Thu Apr 05, 2018 10:45 pm
Btw, thanks for your help, this is really great that you're helping me figure this out, especially in such a timely manner! You guys rule!
bigal420lol
by adafruit_support_carter on Fri Apr 06, 2018 1:44 pm
Well, based on this:
https://github.com/adafruit/rpi-fb-matr ... -367487831
I'm wondering if that guide and code is considered deprecated. Try working through the guide specific to the RGB HAT:
https://learn.adafruit.com/adafruit-rgb ... spberry-pi
and see if that works better.
by bigal420lol on Sun Apr 08, 2018 4:17 am
Still doing the glitchy thing after following the matrix hat guide.
bigal420lol
by adafruit_support_carter on Mon Apr 09, 2018 10:51 pm
Hmmm. I think your soldering looks OK. Cable orientation looks OK. Can you provide some more info on the exact HW you have. What model Pi is it? What's the PID for the 32x32 matrix you have (a little hard tell from photo)?
Did you try this?
https://learn.adafruit.com/adafruit-rgb ... ces#faq-32
by bigal420lol on Mon Apr 09, 2018 11:24 pm
The PID of the LED matrix is 607. My pi is a Raspberry Pi 3 model B. Tried going through the directions in the 'driving matrices' section again, including with the --led-slowdown-gpio flag, but no dice. Even tried re-installing Raspbian and doing the whole thing over again, also to no avail. Still just weird unrecognizable glitchiness.
ALSO tried cloning the original hzeller github repo for the library and following their instructions, including disabling the Pi's sound and including the --led-gpio-mapping flag with the adafruit-hat option, which gave me essentially the same results.
I agree that the soldering looks all right, I took another look at it. Possibly a defective cable or Hat or LED matrix?
bigal420lol
by adafruit_support_carter on Tue Apr 10, 2018 12:17 pm
I'm thinking we should just try another display. First, let's take a closer look at your soldering on the HAT. Can you post another photo that shows the soldering on the HAT with better lighting and focus.
by bigal420lol on Wed Apr 11, 2018 12:04 am
Note that the bottom left two solder joints on the 40-pin part are not actually touching, it just looks that way in the photo because the top one is shaped like a wizard hat.
bigal420lol
by adafruit_support_carter on Wed Apr 11, 2018 1:06 pm
Some of those solder points look marginal enough that it would be worth trying to touch them up. Here's some info on common problems:
https://learn.adafruit.com/adafruit-gui ... n-problems
See the photos below. I've circled some to check for sure, but make sure to go over all of them.
