Chipset for LED Matrix and Waterproofing an IR sensor
by Joty1h1h on Mon Apr 09, 2018 7:48 pm
Hey all, I am curious about the product 64x32 RGB LED Matrix - 6mm pitch
PRODUCT ID: 2276. In the datasheet it says the chipset is 3528RGB SMD which
is a chipset that I'm used to seeing on non-addressible strip. Is this
chipset correct or is it something else?
I was also curious about the product IR Break Beam Sensor - 5mm LEDs PRODUCT
ID: 2168, is it waterproof?
Thank you!!
Joty1h1h
Re: Chipset for LED Matrix and Waterproofing an IR sensor
by adafruit_support_bill on Tue Apr 10, 2018 5:56 am
3528 just refers to the package size of the LED chip. Unlike addressable leds such as Neopixels, the drive chips for the matrix are separate from the actual pixels.
The break-beam sensor modules are not waterproof.
by Joty1h1h on Tue Apr 10, 2018 12:34 pm
Sounds good, thank you! Do you have an IR sensor that is addressable?
Joty1h1h
by adafruit_support_bill on Tue Apr 10, 2018 12:44 pm
This one has an IR channel: https://www.adafruit.com/product/1777
The i2c address is fixed, but you could address multiples using a multiplexer: https://www.adafruit.com/product/2717
by Joty1h1h on Tue Apr 10, 2018 12:51 pm
Hi there, sorry I realized I mistyped! I meant do you have an IR sensor that is water/weather proof?
Joty1h1h
by adafruit_support_bill on Tue Apr 10, 2018 12:54 pm
No we do not.
by Joty1h1h on Thu Apr 12, 2018 8:37 pm
what is the chipset then? we're curious for programming.
adafruit_support_bill wrote:3528 just refers to the package size of the LED chip. Unlike addressable leds such as Neopixels, the drive chips for the matrix are separate from the actual pixels.
Joty1h1h
by adafruit_support_bill on Fri Apr 13, 2018 5:50 am
The manufacturer has not provided us with any schematics or other documentation on these. Please refer to the guide for what details we know:
https://learn.adafruit.com/32x16-32x32- ... trix-works
by Joty1h1h on Fri Apr 13, 2018 1:29 pm
Alright, the documentation only mentions driving one board with an Arduino.
Is it possible to drive these boards with the FadeCandy? https://www.adafruit.com/product/1689
Joty1h1h
by adafruit_support_bill on Fri Apr 13, 2018 1:42 pm
No. The fade-candy doesn't support that protocol.
