My setup and #defines are,
Arduino Mega 2560
Adafruit_FONA shield - FONA_RX 51, FONA_TX 50, FONA_RST 11
Adafruit 2.8" TFT shield - TFT_DC 9, TFT_CS 10, STMPE_CS 8, SD_CS 4
The 2.8" TFT shield works great alone with the Mega.
The FONA shield works great alone with the Mega.
My issue is when I stack the TFT shield on top of the FONA shield, on top of the Mega. I can't read the SD card on the 2.8" TFT any more.
I would post some code, but it's rather large (over 1,000 lines).
I did solder close the ICSP jumpers on the back of the TFT.
Does anyone know why I cannot read the SD on the TFT?
While waiting on some input, I will code a bare bones sketch for the Mega/TFT/FONA.
2.8" TFT Shield / FONA Shield / Mega Pin Callout
- CPPCowboy
- CPPCowboy
Re: 2.8" TFT Shield / FONA Shield / Mega Pin Callout
Here is a simple sketch that has communication between the Mega and FONA working. When I uncomment the tft.begin(); and 6 lines below, the FONA stops communicating with the Mega.
Can anyone explain why this isn't working properly?
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include "Adafruit_FONA.h"
// For the Adafruit FONA shield
#define FONA_RX 51
#define FONA_TX 50
#define FONA_RST 11
// For the Adafruit TFT shield
#define TFT_DC 9
#define TFT_CS 10
#define SD_CS 4
// this is a large buffer for FONA replies
char replybuffer[255];
// Use hardware SPI (on Uno, #13, #12, #11) and the above for CS/DC
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// The STMPE610 uses hardware SPI on the shield, and #8
#define STMPE_CS 8
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
// FONA
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
while (!Serial);
Serial.begin(115200);
Serial.println("Entering setup");
//tft.begin();
//tft.fillScreen(ILI9341_BLACK);
//tft.setCursor(85,150);
//tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK);
//tft.setTextSize(2);
//tft.print("TESTING"); //main Home screen name
// SD Initalation
//pinMode(4, OUTPUT);
/*if (!SD.begin(SD_CS)) {
Serial.println("initialization failed!");
if (!ts.begin()) {
Serial.println("Couldn't start touchscreen controller");
while (1);
fonaSerial->begin(4800);
if (! fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find FONA"));
while (1);
- CPPCowboy
I changed the SD_CS to 53 (Mega 5260) and add the following lines,
pinMode(53, OUTPUT);
digitalWrite(53, HIGH);
Still get SD initialization failed!
My test code is the Adafruit FONAtest.ion shown below,
NOTE: HAD TO DELETE LINES WITH "*I*M*E*I' DUE TO ADAFRUIT ALGORITHM CONTAINS BANNED SPAM WORDS "I*M*E*I" . IT'S THEIR DANG CODE!
// This is a test of the Mega 2560, FONA800H, and TFT
#include <SPI.h>
#include <Wire.h> // this is needed even tho we aren't using it
#include <SD.h>
#include <Adafruit_AM2315.h>
#define FONA_RX 51
#define FONA_TX 50
#define FONA_RST 11
#define TFT_DC 9
#define TFT_CS 10
#define SD_CS 53
// SD card
File myFile;
#define STMPE_CS 8
// this is a large buffer for replies
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
// Hardware serial is also possible!
// HardwareSerial *fonaSerial = &Serial1;
// Use this for FONA 800 and 808s
// Use this one for FONA 3G
//Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
uint8_t type;
while (!Serial);
Serial.begin(9600);
Serial.println(F("FONA basic test"));
Serial.println(F("Initializing....(May take 3 seconds)"));
while (1);
type = fona.type();
Serial.println(F("FONA is OK"));
Serial.print(F("Found "));
switch (type) {
case FONA800L:
Serial.println(F("FONA 800L")); break;
case FONA800H:
Serial.println(F("FONA 800H")); break;
case FONA808_V1:
Serial.println(F("FONA 808 (v1)")); break;
case FONA808_V2:
Serial.println(F("FONA 808 (v2)")); break;
case FONA3G_A:
Serial.println(F("FONA 3G (American)")); break;
case FONA3G_E:
Serial.println(F("FONA 3G (European)")); break;
default:
Serial.println(F("???")); break;
// Optionally configure a GPRS APN, username, and password.
// You might need to do this to access your network's GPRS/data
// network. Contact your provider for the exact APN, username,
// and password values. Username and password are optional and
// can be removed, but APN is required.
//fona.setGPRSNetworkSettings(F("your APN"), F("your username"), F("your password"));
// Optionally configure HTTP gets to follow redirects over SSL.
// Default is not to follow SSL redirects, however if you uncomment
// the following line then redirects over SSL will be followed.
//fona.setHTTPSRedirect(true);
printMenu();
tft.begin();
// SD Initalation
Serial.println("SD initialization done.");
void printMenu(void) {
Serial.println(F("-------------------------------------"));
Serial.println(F("[?] Print this menu"));
Serial.println(F("[a] read the ADC 2.8V max (FONA800 & 808)"));
Serial.println(F("[b] read the Battery V and % charged"));
Serial.println(F("[C] read the SIM CCID"));
Serial.println(F("[U] Unlock SIM with PIN code"));
Serial.println(F("[i] read RSSI"));
Serial.println(F("[n] get Network status"));
Serial.println(F("[v] set audio Volume"));
Serial.println(F("[V] get Volume"));
Serial.println(F("[H] set Headphone audio (FONA800 & 808)"));
Serial.println(F("[e] set External audio (FONA800 & 808)"));
Serial.println(F("[T] play audio Tone"));
Serial.println(F("[P] PWM/Buzzer out (FONA800 & 808)"));
// FM (SIM800 only!)
Serial.println(F("[f] tune FM radio (FONA800)"));
Serial.println(F("[F] turn off FM (FONA800)"));
Serial.println(F("[m] set FM volume (FONA800)"));
Serial.println(F("[M] get FM volume (FONA800)"));
Serial.println(F("[q] get FM station signal level (FONA800)"));
// Phone
Serial.println(F("[c] make phone Call"));
Serial.println(F("[A] get call status"));
Serial.println(F("[h] Hang up phone"));
Serial.println(F("[p] Pick up phone"));
// SMS
Serial.println(F("[N] Number of SMSs"));
Serial.println(F("[r] Read SMS #"));
Serial.println(F("[R] Read All SMS"));
Serial.println(F("[d] Delete SMS #"));
Serial.println(F("[s] Send SMS"));
Serial.println(F("[u] Send USSD"));
// Time
Serial.println(F("[y] Enable network time sync (FONA 800 & 808)"));
Serial.println(F("[Y] Enable NTP time sync (GPRS FONA 800 & 808)"));
Serial.println(F("[t] Get network time"));
// GPRS
Serial.println(F("[G] Enable GPRS"));
Serial.println(F("[g] Disable GPRS"));
Serial.println(F("[l] Query GSMLOC (GPRS)"));
Serial.println(F("[w] Read webpage (GPRS)"));
Serial.println(F("[W] Post to website (GPRS)"));
// GPS
if ((type == FONA3G_A) || (type == FONA3G_E) || (type == FONA808_V1) || (type == FONA808_V2)) {
Serial.println(F("[O] Turn GPS on (FONA 808 & 3G)"));
Serial.println(F("[o] Turn GPS off (FONA 808 & 3G)"));
Serial.println(F("[L] Query GPS location (FONA 808 & 3G)"));
if (type == FONA808_V1) {
Serial.println(F("[x] GPS fix status (FONA808 v1 only)"));
Serial.println(F("[E] Raw NMEA out (FONA808)"));
Serial.println(F("[S] create Serial passthru tunnel"));
Serial.println(F(""));
Serial.print(F("FONA> "));
while (! Serial.available() ) {
if (fona.available()) {
Serial.write(fona.read());
char command = Serial.read();
Serial.println(command);
switch (command) {
case '?': {
printMenu();
break;
case 'a': {
// read the ADC
uint16_t adc;
if (! fona.getADCVoltage(&adc)) {
Serial.println(F("Failed to read ADC"));
} else {
Serial.print(F("ADC = ")); Serial.print(adc); Serial.println(F(" mV"));
break;
case 'b': {
// read the battery voltage and percentage
uint16_t vbat;
if (! fona.getBattVoltage(&vbat)) {
Serial.println(F("Failed to read Batt"));
} else {
Serial.print(F("VBat = ")); Serial.print(vbat); Serial.println(F(" mV"));
if (! fona.getBattPercent(&vbat)) {
} else {
Serial.print(F("VPct = ")); Serial.print(vbat); Serial.println(F("%"));
break;
case 'U': {
// Unlock the SIM with a PIN code
char PIN[5];
flushSerial();
Serial.println(F("Enter 4-digit PIN"));
readline(PIN, 3);
Serial.println(PIN);
Serial.print(F("Unlocking SIM card: "));
if (! fona.unlockSIM(PIN)) {
Serial.println(F("Failed"));
} else {
Serial.println(F("OK!"));
break;
case 'C': {
// read the CCID
fona.getSIMCCID(replybuffer); // make sure replybuffer is at least 21 bytes!
Serial.print(F("SIM CCID = ")); Serial.println(replybuffer);
break;
case 'i': {
// read the RSSI
uint8_t n = fona.getRSSI();
int8_t r;
Serial.print(F("RSSI = ")); Serial.print(n); Serial.print(": ");
if (n == 0) r = -115;
if (n == 1) r = -111;
if (n == 31) r = -52;
if ((n >= 2) && (n <= 30)) {
r = map(n, 2, 30, -110, -54);
Serial.print(r); Serial.println(F(" dBm"));
break;
case 'n': {
// read the network/cellular status
uint8_t n = fona.getNetworkStatus();
Serial.print(F("Network status "));
Serial.print(n);
Serial.print(F(": "));
if (n == 0) Serial.println(F("Not registered"));
if (n == 1) Serial.println(F("Registered (home)"));
if (n == 2) Serial.println(F("Not registered (searching)"));
if (n == 3) Serial.println(F("Denied"));
if (n == 4) Serial.println(F("Unknown"));
if (n == 5) Serial.println(F("Registered roaming"));
break;
/*** Audio ***/
case 'v': {
// set volume
flushSerial();
if ( (type == FONA3G_A) || (type == FONA3G_E) ) {
Serial.print(F("Set Vol [0-8] "));
} else {
Serial.print(F("Set Vol % [0-100] "));
uint8_t vol = readnumber();
Serial.println();
if (! fona.setVolume(vol)) {
} else {
break;
case 'V': {
uint8_t v = fona.getVolume();
Serial.print(v);
Serial.println(" / 8");
} else {
Serial.println("%");
break;
case 'H': {
// Set Headphone output
if (! fona.setAudio(FONA_HEADSETAUDIO)) {
} else {
fona.setMicVolume(FONA_HEADSETAUDIO, 15);
break;
case 'e': {
// Set External output
if (! fona.setAudio(FONA_EXTAUDIO)) {
} else {
fona.setMicVolume(FONA_EXTAUDIO, 10);
break;
case 'T': {
// play tone
flushSerial();
Serial.print(F("Play tone #"));
uint8_t kittone = readnumber();
Serial.println();
// play for 1 second (1000 ms)
if (! fona.playToolkitTone(kittone, 1000)) {
} else {
break;
/*** FM Radio ***/
case 'f': {
// get freq
flushSerial();
Serial.print(F("FM Freq (eg 1011 == 101.1 MHz): "));
uint16_t station = readnumber();
Serial.println();
// FM radio ON using headset
if (fona.FMradio(true, FONA_HEADSETAUDIO)) {
Serial.println(F("Opened"));
if (! fona.tuneFMradio(station)) {
} else {
Serial.println(F("Tuned"));
break;
case 'F': {
// FM radio off
if (! fona.FMradio(false)) {
} else {
break;
case 'm': {
// Set FM volume.
flushSerial();
Serial.print(F("Set FM Vol [0-6]:"));
Serial.println();
if (!fona.setFMVolume(vol)) {
} else {
break;
case 'M': {
// Get FM volume.
uint8_t fmvol = fona.getFMVolume();
if (fmvol < 0) {
} else {
Serial.print(F("FM volume: "));
Serial.println(fmvol, DEC);
break;
case 'q': {
// Get FM station signal level (in decibels).
flushSerial();
Serial.println();
int8_t level = fona.getFMSignalLevel(station);
if (level < 0) {
Serial.println(F("Failed! Make sure FM radio is on (tuned to station)."));
} else {
Serial.print(F("Signal level (dB): "));
Serial.println(level, DEC);
break;
/*** PWM ***/
case 'P': {
// PWM Buzzer output @ 2KHz max
flushSerial();
Serial.print(F("PWM Freq, 0 = Off, (1-2000): "));
uint16_t freq = readnumber();
Serial.println();
if (! fona.setPWM(freq)) {
} else {
break;
/*** Call ***/
case 'c': {
// call a phone!
char number[30];
flushSerial();
Serial.print(F("Call #"));
readline(number, 30);
Serial.println();
Serial.print(F("Calling ")); Serial.println(number);
if (!fona.callPhone(number)) {
} else {
Serial.println(F("Sent!"));
break;
case 'A': {
// get call status
int8_t callstat = fona.getCallStatus();
switch (callstat) {
case 0: Serial.println(F("Ready")); break;
case 1: Serial.println(F("Could not get status")); break;
case 3: Serial.println(F("Ringing (incoming)")); break;
case 4: Serial.println(F("Ringing/in progress (outgoing)")); break;
default: Serial.println(F("Unknown")); break;
break;
case 'h': {
// hang up!
if (! fona.hangUp()) {
} else {
break;
case 'p': {
// pick up!
if (! fona.pickUp()) {
} else {
break;
/*** SMS ***/
case 'N': {
// read the number of SMS's!
int8_t smsnum = fona.getNumSMS();
if (smsnum < 0) {
Serial.println(F("Could not read # SMS"));
} else {
Serial.print(smsnum);
Serial.println(F(" SMS's on SIM card!"));
break;
case 'r': {
// read an SMS
flushSerial();
Serial.print(F("Read #"));
uint8_t smsn = readnumber();
Serial.print(F("\n\rReading SMS #")); Serial.println(smsn);
// Retrieve SMS sender address/phone number.
if (! fona.getSMSSender(smsn, replybuffer, 250)) {
Serial.println("Failed!");
break;
Serial.print(F("FROM: ")); Serial.println(replybuffer);
// Retrieve SMS value.
uint16_t smslen;
if (! fona.readSMS(smsn, replybuffer, 250, &smslen)) { // pass in buffer and max len!
break;
Serial.print(F("***** SMS #")); Serial.print(smsn);
Serial.print(" ("); Serial.print(smslen); Serial.println(F(") bytes *****"));
Serial.println(F("*****"));
break;
case 'R': {
// read all SMS
uint16_t smslen;
int8_t smsn;
smsn = 0; // zero indexed
smsnum--;
} else {
smsn = 1; // 1 indexed
for ( ; smsn <= smsnum; smsn++) {
if (!fona.readSMS(smsn, replybuffer, 250, &smslen)) { // pass in buffer and max len!
Serial.println(F("Failed!"));
break;
// if the length is zero, its a special case where the index number is higher
// so increase the max we'll look at!
if (smslen == 0) {
Serial.println(F("[empty slot]"));
smsnum++;
continue;
break;
case 'd': {
// delete an SMS
flushSerial();
Serial.print(F("Delete #"));
Serial.print(F("\n\rDeleting SMS #")); Serial.println(smsn);
if (fona.deleteSMS(smsn)) {
} else {
Serial.println(F("Couldn't delete"));
break;
case 's': {
// send an SMS!
char sendto[21], message[141];
flushSerial();
Serial.print(F("Send to #"));
readline(sendto, 20);
Serial.println(sendto);
Serial.print(F("Type out one-line message (140 char): "));
readline(message, 140);
Serial.println(message);
if (!fona.sendSMS(sendto, message)) {
} else {
break;
case 'u': {
// send a USSD!
char message[141];
flushSerial();
uint16_t ussdlen;
if (!fona.sendUSSD(message, replybuffer, 250, &ussdlen)) { // pass in buffer and max len!
} else {
Serial.print(F("***** USSD Reply"));
Serial.print(" ("); Serial.print(ussdlen); Serial.println(F(") bytes *****"));
/*** Time ***/
case 'y': {
// enable network time sync
if (!fona.BANNED(true))
Serial.println(F("Failed to enable"));
break;
case 'Y': {
// enable NTP time sync
if (!fona.enableNTPTimeSync(true, F("pool.ntp.org")))
break;
case 't': {
// read the time
char buffer[23];
fona.getTime(buffer, 23); // make sure replybuffer is at least 23 bytes!
Serial.print(F("Time = ")); Serial.println(buffer);
break;
/*********************************** GPS (SIM808 only) */
case 'o': {
// turn GPS off
if (!fona.enableGPS(false))
Serial.println(F("Failed to turn off"));
break;
case 'O': {
// turn GPS on
if (!fona.enableGPS(true))
Serial.println(F("Failed to turn on"));
break;
case 'x': {
int8_t stat;
// check GPS fix
stat = fona.GPSstatus();
if (stat < 0)
Serial.println(F("Failed to query"));
if (stat == 0) Serial.println(F("GPS off"));
if (stat == 1) Serial.println(F("No fix"));
if (stat == 2) Serial.println(F("2D fix"));
if (stat == 3) Serial.println(F("3D fix"));
break;
case 'L': {
// check for GPS location
char gpsdata[120];
fona.getGPS(0, gpsdata, 120);
Serial.println(F("Reply in format: mode,longitude,latitude,altitude,utctime(yyyymmddHHMMSS),ttff,satellites,speed,course"));
else
Serial.println(F("Reply in format: mode,fixstatus,utctime(yyyymmddHHMMSS),latitude,longitude,altitude,speed,course,fixmode,reserved1,HDOP,PDOP,VDOP,reserved2,view_satellites,used_satellites,reserved3,C/N0max,HPA,VPA"));
Serial.println(gpsdata);
break;
case 'E': {
flushSerial();
Serial.print(F("GPS NMEA output sentences (0 = off, 34 = RMC+GGA, 255 = all)"));
} else {
Serial.print(F("On (1) or Off (0)? "));
uint8_t nmeaout = readnumber();
// turn on NMEA output
fona.enableGPSNMEA(nmeaout);
break;
/*********************************** GPRS */
case 'g': {
// turn GPRS off
if (!fona.enableGPRS(false))
break;
case 'G': {
// turn GPRS on
if (!fona.enableGPRS(true))
break;
case 'l': {
// check for GSMLOC (requires GPRS)
uint16_t returncode;
if (!fona.getGSMLoc(&returncode, replybuffer, 250))
if (returncode == 0) {
} else {
Serial.print(F("Fail code #")); Serial.println(returncode);
break;
case 'w': {
// read website URL
uint16_t statuscode;
int16_t length;
char url[80];
flushSerial();
Serial.println(F("NOTE: in beta! Use small webpages to read!"));
Serial.println(F("URL to read (e.g. www.adafruit.com/testwifi/index.html):"));
Serial.print(F("http://")); readline(url, 79);
Serial.println(url);
Serial.println(F("****"));
if (!fona.HTTP_GET_start(url, &statuscode, (uint16_t *)&length)) {
break;
while (length > 0) {
while (fona.available()) {
char c = fona.read();
// Serial.write is too slow, we'll write directly to Serial register!
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
loop_until_bit_is_set(UCSR0A, UDRE0); /* Wait until data register empty. */
UDR0 = c;
#else
Serial.write(c);
#endif
length--;
if (! length) break;
Serial.println(F("\n****"));
fona.HTTP_GET_end();
break;
case 'W': {
// Post data to website
int16_t length;
char url[80];
char data[80];
flushSerial();
Serial.println(F("NOTE: in beta! Use simple websites to post!"));
Serial.println(F("URL to post (e.g. httpbin.org/post):"));
Serial.println(F("Data to post (e.g. \"foo\" or \"{\"simple\":\"json\"}\"):"));
readline(data, 79);
Serial.println(data);
if (!fona.HTTP_POST_start(url, F("text/plain"), (uint8_t *) data, strlen(data), &statuscode, (uint16_t *)&length)) {
break;
UDR0 = c;
#else
Serial.write(c);
#endif
length--;
fona.HTTP_POST_end();
break;
case 'S': {
Serial.println(F("Creating SERIAL TUBE"));
while (1) {
while (Serial.available()) {
delay(1);
fona.write(Serial.read());
break;
default: {
Serial.println(F("Unknown command"));
printMenu();
break;
// flush input
flushSerial();
void flushSerial() {
Serial.read();
char readBlocking() {
while (!Serial.available());
return Serial.read();
uint16_t readnumber() {
uint16_t x = 0;
char c;
while (! isdigit(c = readBlocking())) {
//Serial.print(c);
Serial.print(c);
x = c - '0';
while (isdigit(c = readBlocking())) {
Serial.print(c);
x *= 10;
x += c - '0';
return x;
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout) {
uint16_t buffidx = 0;
boolean timeoutvalid = true;
if (timeout == 0) timeoutvalid = false;
while (true) {
if (buffidx > maxbuff) {
//Serial.println(F("SPACE"));
break;
char c = Serial.read();
//Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
if (c == '\r') continue;
if (c == 0xA) {
if (buffidx == 0) // the first 0x0A is ignored
continue;
timeout = 0; // the second 0x0A is the end of the line
break;
buff[buffidx] = c;
buffidx++;
if (timeoutvalid && timeout == 0) {
//Serial.println(F("TIMEOUT"));
break;
delay(1);
buff[buffidx] = 0; // null term
return buffidx;
- CPPCowboy
I am one slow learner : )
SPI.begin(); is a beautiful line
I am in no way associated with Simon Monk, but his two books on Programming Arduino are the best ! !
